Dyno Challange???
Old 01-14-2010 | 10:48 PM
HotPursuit's Avatar
Originally Posted by thumper038
Thanks to you I cant get the image of hitting Tonya out of my mind
She might make you a good hand!!
HotPursuit is offline
Old 01-14-2010 | 10:49 PM
FREEDOM US1's Avatar
Skater Brother
Originally Posted by HotPursuit
Whats up crazy mofo!! You going to miami?? I like the way you think.
No sure but probably!!! Need to do some MOFO chit!!!! U going?
FREEDOM US1 is offline
Old 01-14-2010 | 11:00 PM
This should be interesting.
JollyJohnny is offline
Old 01-14-2010 | 11:03 PM
HotPursuit's Avatar
Only if your going!!!
Old 01-14-2010 | 11:08 PM
I am thinking dyno challege for informative purposes like does your 1200 make 1200 compared to this one. I also like what Gatorone said about after the challenge put the motors in the boat and then run 200 miles. That would really see what builders have there stuff together. And a plus for them is they could then charge more if it worked.
I also think different companies building motors dynoing them and then putting them in one test boat obviously this could take a while and the companies would have to have extra motors to spare. But this would be the most even playing field to compare motors obviously not a perfect comparison but it would be pretty fair.
db71 is offline
Old 01-14-2010 | 11:11 PM
You know you want it.
Old 01-14-2010 | 11:13 PM
HotPursuit's Avatar
Boat weight gears props rpms slip = speed
Set up has won more races than HP and dyno time!!!!
Old 01-15-2010 | 04:02 PM
Ptufaro's Avatar
That is the truth good example is the super cat light class same length skaters, mti, or doug wright will run away from one another just b/c of set up.
But none of this is new just the wheels turning over winter.
Ptufaro is offline
Old 01-15-2010 | 04:54 PM
HotPursuit's Avatar
Hows the MTI coming????
Old 01-15-2010 | 06:34 PM
Ptufaro's Avatar
Good just a bit slow.
New baby boy is here and don't have quite the spare time as I used to.
I am shooting for this summer
Ptufaro is offline
