Exhaust Gas Temp Guage
Old 06-30-2007 | 08:17 AM
Registered User
Default o2 sensors in marine manifolds.
sorry forgot to include picture Ford 351 windsor pictured other applications including buick v6 gm 5.7 LS1 6.0 LS2
julius750 is offline
Old 06-30-2007 | 09:05 AM
GLH's Avatar
GLH
The Bros here have a 50 hustler with trip 900hp's and they run those.
The number you mentioned is what they go by. They shut off if it hits 1400. usually around 1100 I think.
Hope this helps.
GLH is offline
Old 06-30-2007 | 09:14 AM
MitchStellin's Avatar
On the truck if I see 1400 I back off but I never shut it down, I want the exhaust to keep flowing as it can cool, a boat is a different story though. I let it idle until it hits 400 or so. I see 1100 most of the time, only higher if I am towing a big load at speed up a good grade.
MitchStellin is offline
Old 06-30-2007 | 11:08 AM
What type of gas enging needs a EGT guage. I don't have any experience with high hp gas engines. I have a little experience with diesels. I installed a egt and boost guage on a diesel in a truck. The temp guage was installed pre turbo.
We ran the engine without any mods to establish baseline data, installed an aftermarket chip, and gathered more data. Installed a propane injection system, and then you really had to watch it.
EGT's without mods 900 deg F
EGT's with chip 12-1300 on top end
EGT's with chip and propane, had to back off at 100mph, egt's touched 1500 for a sec,
Am told not to exceed 1325 deg F pre turbo.
Mackattack is offline
Old 07-02-2007 | 09:29 AM
I run and have run pyro's for sometime...first with my IMCO manifolds & now with my CMI's. BTW, you can send your CMI headers back to CMI and they will install the sensor coupling. I always encourage my customers to order their CMI headers with the sensor coupling, even if they do not plan on using it right away.
BTW, I usually mount the probe on the #1 and/or #8 cylinders and keep the temps at 1250 or below.
tpmarine.com is offline
Old 07-02-2007 | 09:38 AM
articfriends's Avatar
I had gaffrig egts in my lightning headers in #7 & 8,they read 1500 to pegged all the time when under throttle,plugs were black and sooty. I quit paying attention to them because they obviously were way off. I tested them once with a comtrolled heat source and compared them to my pyro 2000 gauges on my snowmobile-they read 200-300 degrees too hot so don't waste your time on the gaffrigs. I currently have a 02 bung in my stainless marine 3's in #8,about 1 inch from exhaust flange on bottom,on crocketts innovate it seemed very accurate,Smitty
articfriends is offline
Old 07-02-2007 | 09:40 AM
Ever done any hp testing compared to cmi's or stainless marine 3's? Smitty
rssteiny
5
06-30-2008 06:49 PM
YOLO
04-07-2008 05:07 PM
Rebel_Heart
4
08-13-2006 02:31 PM
JON242
2
07-07-2004 11:22 AM
MnFastBoat
1
07-13-2002 08:36 AM
