Twin turbo engines
Old 05-10-2010 | 08:33 PM
  #71
Originally Posted by Bigyellowcat
standard using weather station
probably a couple hundred more hp then your engine builder made for your boat and we don't have to use a fake correction factor...
don't think so...you gotta be joking, just ask thumper
villecountryclub is offline
Old 07-06-2010 | 11:28 PM
  #72
cougarman's Avatar
not bad for our 5 psi pump gas setting... lots of cubic inches and no blower drag equals lots of power
http://www.youtube.com/watch?v=cDJ0sdHid04
Good Morning Tyson,
Been sometime since I have checked in, have you started to water test these yet? If so do you have any feed back ? Thanks Jon
cougarman is offline
Old 07-07-2010 | 11:26 AM
  #73
Very nice engines!
Dueclaws is offline
Old 07-08-2010 | 04:25 AM
  #74
What boost was that pull?
That thing is off the ricta!
I thought it said something in the 6.5psi range but its real fuzzy on my screen and i cant quite tell.
Am i close?
Kurt Hamilton is offline
Old 07-08-2010 | 10:12 AM
  #75
Am i close?
I think the answer is on Post #65 of this thread.
E Dock DD is offline
Old 07-08-2010 | 12:21 PM
  #76
Audiofn's Avatar
Charter Member #232
Damn those are some nice looking mills!
Put your best foot forward!
Audiofn is offline
Old 07-08-2010 | 03:51 PM
  #77
Ah
Too busy clicking on the you tube link to read the post properly.
Thats unreal power for 5psi!
We had a twin turbo 510ci and it only made 1295hp at 17psi.
Admittedly our cam was a big factor in not making any more than this but we were running no transmissions and needed the low end to plane with skiers.
Still thats mind blowing.
Old 07-10-2010 | 12:51 AM
  #78
Nice work on the engines, and for machine work I might have to ring you guys up since my miller retired years back. Guessing those were pro-dominator intakes you started machining with?
Nice to see excellent low profile work using EFI and chargers. Maybe you can give Reggie a true piston powered cat to chase...
-K
kidturbo is offline
Old 07-31-2010 | 01:07 PM
  #79
Roger 1's Avatar
Very nice work.
Roger 1 is offline
Old 08-01-2010 | 08:24 PM
  #80
Any updates on this rig? Will it be ready for the Shootout?
Killer motors BTW.
JohnnyZ is offline
