stepped hull dilema
Old 04-26-2010 | 08:22 PM
Montauk Crossbow's Avatar
Default stepped hull dilema
Last season I installed a thru hull depth and temp transducer on my twin stepped hull Donzi ,I put it about 3 feet ahead of the transom and aft of the second step by about 2-3 feet, problem being at speed ,or even anything above idle I lose signal ,my thought was move the transducer aft away from the step ,Someone today said I need to move it foward of the first step , Anybody done this with any success ???,What is the correct placement ? Thanks in advance Rich
Montauk Crossbow is offline
Old 04-26-2010 | 08:26 PM
I lose my signal at speed also, kinda thought that was just how it was.
richanton is offline
Old 04-26-2010 | 08:45 PM
lawdocx3's Avatar
Mine is forward of the step. I have never had a problem with it.
lawdocx3 is offline
Old 04-26-2010 | 08:49 PM
Transducers just don't like the aerated water, apparently.
The way I've always looked at this is .......... That at any speed much above an idle you have in fact hit bottom just slightly before the depth sounder tells you that you might. After the fact the depth sounder reading combined with the mangled prop or missing lower serves to confirm the fact that you have indeed hit something.
Depth sounders on step bottom boats are likened in use to tits on a nun!
RaggedEdge is offline
Old 04-26-2010 | 08:50 PM
If you get trimmed out the transducer may be out of water when it's placed forward of the step.
Interceptor is offline
Old 04-26-2010 | 08:57 PM
good call . and i love your compairison
smokin' gun is offline
Old 04-26-2010 | 09:05 PM
Just call it like I see it!
Have a very similiar opinion on GPS units.
I have one! In the cabin where it can't obstruct my view!
Old 04-27-2010 | 12:08 AM
The only time the depth sounder works on my Advantage Cat is when she is stationary- 5mph. Faster than that and no workie.
Darrell.
DMOORE is offline
Old 04-27-2010 | 05:30 AM
sean stinson's Avatar
The Illustrious One
Veteran: Navy
You need to put it forward of the step...That way it is in clean water and can maintain a good signal!!!!
Dying,....Is the day worth living for!!!!!!
sean stinson is offline
Old 04-27-2010 | 09:29 AM
Tres's Avatar
Install At rear transom, inline with lift strake.
Tres is offline
