Pantera 41' Launched
#71
It was the mold that Thad Allen had toole dwhen the new revived Apache was coming on line before all the bs now then the steps you have to talk to Pepe about but I am pretty sure you can still get a straight bottom version....
The Pacific......most peoples rough is calm to us....Pt Conception is a good one to try to compare you silly little bumps to.....
#78
Hahaha! Ask stinson about the Pacific, he's been caught slippin out here before!
the big blue will bite'cha when you least expect it.
It appears, with that package, you could run out in some big water, lay the sticks down and sip a martini in that beast!
Just to clarify, this is an older apache mold that was stepped? Thought I read that somewhere.
the big blue will bite'cha when you least expect it. It appears, with that package, you could run out in some big water, lay the sticks down and sip a martini in that beast!
This included "inches" of additional height to make the bottom straight and level as the original tooling had a bad rocker in it.
It was all done as a non-stepped hull with a new and improved straight bottom, NO ROCKER!!!
Then Pantera bought the tooling and made it their own by adding a stepped insert to modify and improve the running surface - this IS NOT the T4 that Steve 1 was tooling up, it is the original straight bottom molded 41 that was to be a retro version of the original for the new Thad Allen Apache.
hope this helps!
just sayin... now that thay have built one i need a price so i can strart a rainy day fund for a new boat! pantera has always been on the top of my list for the next boat!
