Technical Questions For Steve 1
#51
Question for everyone.
Its June 2010.
What hull shape and length, by what boatbuilder, that we know has been UNCHANGED is out there now in use in the GREATEST NUMBERS ?
Would it be one of the Fountain hulls because of the huge numbers sold over the years ?
What V hull ?
and what CAT hull ?
Its June 2010.
What V hull ?
and what CAT hull ?
V hulls with no changes is tough since there has been some tweaking along the way notch/un-notch transom/pad/no pad changes etc. The 38 T/S TG is relatively unchanged for a a 10-11 year run. The 35/38/42 Fountain is relatively unchanged albeit trim changes like Lightning/Executionere etc. Fountain has built a lot of boats but Formula was pumping out a lot of 353/382 Fastech's also.
Sunsation re-did their 32 in a twin step in 06 but by 08 added a pad so tweaks like that are what I mean for changes.
#52
What Cat hull do you think is the most prolific?
Would it be one of the Eliminator hulls ?
#53
The Pantera at 10,000# Poker run Bagged and Cored with everything imaginable onboard and the 900's @ 125 looking at the information I have seen.
#55
#56
Alec ,The Pantera has 525's and is at it's legal weight of 10,600# I have heard 93 mph . The old Apaches with 900's would hit 100+ from the feed back I have got.
#57
that would be a sweet ride
08 OPA High Points Champion
#58
#59
Thanks Steve
Lets say you had the opportunity to start from scratch.
We see the economy, and how the trends have changed in the past few years.
You can build one model of boat ONLY.
You can have ONE mold, ONE ONLY.
Given those parameters, what would you build?
V ? Cat? Length? Power? Drives?
The boat isnt for you, its for commercial customers, so give us your impression of what you would build to get the most volume out of.
#60
Thanks Steve
You said one set of molds, OK Open Fisherman deck and I would KRYPTON infuse the boat and have all the material Kitted, the first piece on top of the box is the first one used, Resins got to be careful here a good Vinylester as nothing wears like a good gelcoat job.
