Stereo gurus. need help
1) wired to the wrong ohms maybe
2) amp is under powered how is an amp under powered?
3) power and ground wire to small it has a huge freakin wire abt 3/4"..lol sorry dont know gage
4) ground wire not grounded well dont think so bc sometimes it will jam then just cut off. its cut off while sitting on the trailer
here are the speakers i have
http://www.sonicelectronix.com/item_...o+MM651UM.html
Amps can easily be underpowered for the load they are seeing. As a matter of fact it is much better to have an amp that is overpowered (truly more power than you need, not just over-rated) than to have an amp that is under powered. That amp will have to work harder to produce the desired SPL and will more than likely start clipping. This is where the waveform flattens out because the amp is not stable at the required current. This causes distrtion and serious heat issues.
Sounds like this could be your problem and it could be as the others have noted directly related to how your 8(?) 4 ohm speakers are wired to the amp.
Also, you are on the right track re: the ground issue and the amp shutting off quickly. If it were a ground problem it would probably be a softer clip, for lack of better terms. However in a boat the ground issue would have nothing to do with whether the boat is on the trailer. It either has a good ground or not.
here is the amp and speakers im running.
http://www.sonicelectronix.com/item_...r+ZX850.4.html
so this is what i done last night
ohm on each speaker lead is 3.8ohm
if i wire 2 speakers parallel it bounces from 1.9 to 2
fyi my radio volume maxes at 34 and the amp gain is at a quarter
I hooked 4 speakers to its own channel and it played fine to 34 as soon as i changed one channel to 2 speakers wired parallel it cut out. If i lowered the volume to 25 it will come back on and play. but on high pitch sounds at volume 25 it cuts back out and 3-4 seconds pass and it comes back
did i confuse you?
did i confuse you?
The ohm reading is a dc resistance measurement. The impedance can be much different, and it always varies with frequency. That is what the amp really sees.
Either way, sounds like the amp is not stable at the lower impedance you are trying to drive. Did you check each speaker ohm reading at the amp?
Why you say high pitch, you mean volume (spl) or bass, or highs?
Just for fun, raise your low pass filter up (high frequency, meaning less low frequency to the speakers) and see what happens.
this stereo is really kicking my a$$
the worse is when the girls are booty shaking and just when the party is about to get started the stereo cuts out and everyone looks at me like WTF
You can try turning your gain up on the amp. It probably won't make a difference but it is worth a shot.
It seems to me your amp isn't liking the 2 ohm load. I'm pretty sure the real solution to this is to add another 4 channel amp to the system.
