Propshaft height question
Old 06-29-2010 | 11:45 AM
Default Propshaft height question
When measuring "propshaft height", do you use the center of the propshaft?
Mike
mikesufka is offline
Old 06-29-2010 | 12:14 PM
Mike
when measuring prop shaft height we measure from the center of the "point" on the lower unit
tzrider is offline
Old 06-29-2010 | 07:37 PM
Originally Posted by tzrider
Mike
The center of the prop shaft is "higher" than the "point" of the lower unit, correct?
Which is right for setting up a Spectre? Measure from where????
Thanks.
Old 06-30-2010 | 12:07 AM
i always measure with the motors trimmed a little bit positive to the center of the prop shaft near the props. depending on where the motors are trimmed at it changes inbetween the point and the prop end.
demag67 is offline
Old 06-30-2010 | 07:43 AM
Thanks.
Whether you measure from the point of the bullet or the center of the propshaft, It is just a reference point to help you dial in the boat. Boat performance and your seat of the pants is what dictates the drive height. Make sure you keep a close eye on water pressure when testing drive heights.
Alvin
TeamSkater is offline
