Skater 30 / ILMOR Indy Upgrade
#134
#135
Comment:
Perhaps no one is telling you the truth. I will say it your running the wrong gear ratio right out of the box. Note: It is your boat you run what you want but if it were me and it's not I would tell them hey can we try the 1.39 GR
I don't get it why 37, 39, and 40 pitch props???
I would change it now to the 1:39 and run some better props 16.5 X 33+- super cat lite props if it can pull it if not then a 32 pitch.
As for your slip calculations can we have the data on that 10% in a pleasure boat cat. I do the slip calculations and it comes out 12%--- which is fantastic in any event for a pleasure boat catamaran.
KAP
.I don't get it why 37, 39, and 40 pitch props???
KAP
#138
Comment:
KAP
KAP
At the end of the day I can go either way 1.39 or 1.50 at No Cost to me but the last 3 ILMOR Indy twin engine cats built went 1.39. We have all the data, props, acceleration, speeds etc on those boats & can easily mirror them so why not try something different?? If 38-40 pitch props were totally inefficient & virtually useless then why would they offer them? IMO they make them b/c there's a market for them. The 35's & 37's that have been tested so far were SCL props & the gain over a standard cut prop is only about 1-2mph & they're only rated up to 700h.p. I'm told.
With regard to slip what rpm did you use b/c my guess is thats where you may be off?? According to Peter Hledin round ear bravo props are considered efficient @ 10-12% & cleaver (#6) props closer to 6-8% slip. I don't know nor do I claim to know but it's worth my time to allow the man to test his theories as to what he thinks will yield me the best overall package. Keep in mind that Bob Teague is an ILMOR distributor & has provided input & that overall this is a collaborative effort between ILMOR, Skater, Hering & myself. My Skater is the FIRST retro-fit boat, all others have been packages. Keep in mind the H.P. & torque curves are different between the Gen3 710 engine I have & the Gen4 725 engines that are offered now.
The worst that could happen is we find out what we thought in theory was a good idea ended up not working. I can't tell you how many things show promise in the wind tunnel & aren't worth a darn on the race track! Thats why we call it testing!
I feel I've been very open & honest about this project as it's a learning experience for all involved. This Thread has over 23k views in 1 mo so there must be some interest in it's success.
#139
Looks like everything is coming together nicely for you.
