Skater 30 / ILMOR Indy Upgrade >
Old 10-12-2010 | 08:39 AM
  #241
Here's a link to a video Hering sent me of a 200hp Outboard running 100mph. Pretty cool to see what is & isn't in the water at speed.
I'm going to attempt to get a video of my ILMOR Indy drives in action.
http://www.facebook.com/video/video....d=146415149606
NASCAT is offline
Old 10-12-2010 | 10:28 AM
  #242
That is an awesome video.
Philm is offline
Old 10-12-2010 | 07:05 PM
  #243
C_Spray's Avatar
Diamond Member #001
I tried the same thing, but forgot about all the water coming out of the tailpipes:
Ilmor 725/Indy - the business end.
I'll save it at high-res next time...
C_Spray is offline
Old 10-12-2010 | 08:52 PM
  #244
What did you record it with, GoPro?? Mounted to what, cleat??
NASCAT is offline
Old 10-15-2010 | 09:22 PM
  #245
C_Spray's Avatar
Diamond Member #001
Yep. GoPro HD. Just used their suction mount on the deck. Did you get a chance to test anything today?
C_Spray is offline
Old 10-18-2010 | 08:16 AM
  #246
Swede's Avatar
Another video from this weekend with C-spray as co-pilot.
BOAT PHOTOS HERE:
http://www.performance-images.com/Powerboats
Swede is offline
Old 10-18-2010 | 10:03 AM
  #247
Dave,
Thanks for taking the time to come out yesterday!
NASCAT is offline
Old 10-20-2010 | 04:11 PM
  #248
Default Mercury Props & Nose Cone Testing
Testing Day 1 Sat 10/15- 2 people, 2/3 fuel, 50-70 deg (warms up quick), windy 1' chop. No visible outdrive video, poor cam location.
Run 1- Baseline w/ Hering 16.5 x 37 SCL's & stk nose cones. 3000rpm harmonic vibration, 65-95 hop, good acceleration but difficult to make use of w/ the hop, settles down at 100mph, top speed 130@ 6000-6050rpm level to -1 Neg trim
Run 2- Merc 16.5 x 37 CL's & stk nose cones. 3000rpm harmonic vibration, 65-95 hop, good acceleration but difficult to make use of w/ the hop, settles down at 100mph, top speed 130@ 6000-6050rpm, likes level to +1 pos trim.
Run 3- Merc 16.5 x 39 CL's stk nose cones. 3000rpm harmonic vibration, 65-85 hop, settles down a little sooner, top speed 133@ 5900-6000rpm, likes level to +1 pos trim.
Testing Day 2 Sun 10/16- 3 people, 2/3 fuel, 60-70 deg (warms up quick), calm/flat. (since there was no real performance gain or noticeable advantage to the Merc props I performed all Day 2 testing w/ the Hering 37’s SCL’s for consistency purposes which have been the all around top performers to date.)
Run 1- Same as Run 1 baseline from Sat, no difference in performance but captured some video w/ stk nose cones (see below)
Run 2- Hering 16.5 x 37 SCL’s w/ pointed nose cones & video (see below), no noticeable difference time to plane, 3000rpm harmonic vibration remained, porpoised same 65-95mph but boat felt very edgy, light & unsettled @ 110mph+. I wasn’t comfortable trying to take it past 120mph. (I shared this w/ Bob Teague & he said he noticed no difference on the Eliminator & nor should I have b/c once it’s out of the water it’s out of the water)
Nose cone vids below, tried several mounting locations even 2 cameras at one time but unfortunately lots of tunnel spray & tailpipe water interference. Best when watched in full screen, cones come into view intermittently especially coming off throttle, drag cursor to FF thru the clip.
http://www.youtube.com/watch?v=GPKe2O9XgDQ Stock nose cone video Sunday Run 1
http://www.youtube.com/watch?v=9KglqTe0-VU Pointed nose cone video Sunday Run 2
NASCAT is offline
Old 10-20-2010 | 04:30 PM
  #249
Turbojack's Avatar
do they think they can fix the harmonic vibration at 3k?
Turbojack is offline
Old 10-20-2010 | 07:11 PM
  #250
If you trim it up a little more, can you pick up any speed/rpm's with the 37's ?
I'm still thinking you should try some 16.25 x 38's
stainless is offline
