Skater 30 / ILMOR Indy Upgrade >
Old 06-17-2011 | 08:49 AM
  #351
Originally Posted by Marginmn
So where is the sweet spot to run these 710s? The set I put in my Fountain is turning 6100 - 6200 running with the same props that I had on it with the 625's that were turning 5750. Should I step up a pitch and bring it down to 5900?
Ultimately this is a question for Ilmor / Hering both of whom you'll find to be very helpful in getting you zero'd in on your ultimate goal. You gained 200+ HP so I would think you automatically go up 1 or 2 pitch sizes.
I don't prop my boat for a certain cruise range or RPM b/c I don't boat like that. Here in NC on LKN I blast to where I'm going & I'm done or I cruise around the lake in the 60-70 mph range but it doesn't amount to more than a 15-20 min ride so I don't bother to prop for cruising speeds. The remainder of my boating is poker runs which is where I concentrate more of my test & tune efforts. My boat's sweet spot is 100-110mph. It's settled in & on rails & extremely comfortable like a Sunday drive in a 7 series BMW.
B/C I upgraded to the INDY drives my options increased. I basically try to balance top speed w/ acceleration & the fact that I don't run my boat on 1/4 tank w/ 2 on board for top speed #'s on a regular basis.
I start where Hering suggests then keep trying to get more top speed always conducting my testing w/ a 1/4 tank 1 - 2 on board recording top speed & RPM. When I get to the point I can't spin the bigger pitch to within 100-150 of redline I go back to a set of props that can. Then evaluate my ability to get on plane as well as roll on acceleration w/ those props w/o tucking the drives in or using any tab as a crutch. Once I zero in on a prop that can get me on plane, has good roll on performance & can tag the limiters in the right conditions I know that I'm pretty much there b/c when I add fuel or passengers I won't be on the limiters anymore & I still can use the drives & tab to get on plane IF NECESSARY. At this point I can drop 1 pitch size or work w/ Hering to trim some diameter or cup instead. I allow them to make the suggestions based on the boating I do. I end up w/ a very well rounded set of props this way. The ILMOR's are fuel efficient as it is & cruising probably only makes up 15-20% of my boating.
I believe I'll end up w/ a pr of Hering 5 blade 37 or 38 SCL's w/ my 1.50 drives.
Jeff Johnston or Ben Robertson at Hering can assist you as could Ben Robertson Sr. at BAR Marine here in SC. He is a racer and knows the ILMOR & Fountain product very well.
Hope this helps and good luck.
NASCAT is offline
Old 06-17-2011 | 09:14 AM
  #352
sure does, thanks a bunch.
Marginmn is offline
Old 06-17-2011 | 11:21 AM
  #353
Ptufaro's Avatar
Nice
Ptufaro is offline
Old 06-17-2011 | 11:35 AM
  #354
Cash Bar's Avatar
Mod Squad Enforcer
Originally Posted by NASCAT
Try this http://www.youtube.com/watch?v=F49TDdhm0B4
JAX PR start, Catz Azz leggs me on the Starboard 30 secs in then Albert vaporizes me on the port 1 min in.
That video sucks. All I see is some river and all I hear is some obnoxious engine noises.
Nice video Mike. That shows how far Albert had to go to catch R&C with the lead they had on your right early on in the vid.
www.gregsellswaterfront.com
Cash Bar is offline
Old 06-17-2011 | 12:47 PM
  #355
Agreed b/c I probably started 200yds ahead of Albert & it took him a while to catch me. In the end & depending on how far the leg is to the 1st card stop is I think the quicker accelerating boat will out perform many of the faster overall topend boats. Thats the route I'm going back too anyway.
NASCAT is offline
Old 06-17-2011 | 12:53 PM
  #356
NasCat
How fast were you running? I am bringing a 28 Skater to Lake Norman in July 9th -17th. Would love to check out the boat if you are around. Nice Video!
Double Rigged is offline
Old 06-18-2011 | 12:24 AM
  #357
Originally Posted by Double Rigged
NasCat
In Jax 125-130.
I'll be in VA at Jammin on the James the weekend of the July 9th, 10th but if you are here another week I'm sure we can catch up. Keep me posted.
Michael
NASCAT is offline
Old 06-18-2011 | 08:52 AM
  #358
nice video boat looked sweet up and running..I think we were the only two lucky enough to snag crab traps!!
32-DD is offline
Old 06-18-2011 | 11:47 AM
  #359
I think u more than snagged. The prop was embeded in the trap. And those poor little blue crab. U blended them into crab soup lol
29 sst is offline
Old 06-18-2011 | 12:00 PM
  #360
Von Bongo's Avatar
Sounds like a green-white-checkered strategy
Von Bongo is offline
