Technical ? converting Bravo to a #6 drive,....Input please >
Old 08-14-2010 | 07:32 PM
cougarman's Avatar
Default Technical ? converting Bravo to a #6 drive,....Input please
When converting a bravo drive to a #6 plug-in.
Does anyone know how far this will push the engine forward?
There is a certain amount of hardware your going to trade and put the tranny and tail stock in place of it.
So if anyone has knowledge of the extra space required it would be greatly appreciated.
Jon
cougarman is offline
Old 08-14-2010 | 08:50 PM
RMPRam's Avatar
John,
Give me a call and I will be able to tell you.
Gary Kollofski
763-473-8963
RMPRam is offline
Old 08-14-2010 | 11:49 PM
t500hps's Avatar
21 and 42 footers
If converting a bravo boat I would seriously consider the arneson SD-6 conversion kit......leaves the motor in the same place and puts the transmission in an extension box.
t500hps is offline
Old 08-15-2010 | 12:57 AM
It's been a while but I want to say it's about 12" forward.
Eddie
Young Performance is offline
Old 08-15-2010 | 06:52 AM
JIMKID Motorsports's Avatar
cougarman why not consider XPOWER drive very simple he now has a stainless gimble ring for them was weak link before call i have them on my skater
JIMKID Motorsports is offline
Old 08-15-2010 | 07:34 AM
what about a nxt?
rmfriday is offline
Old 08-15-2010 | 07:40 AM
thisistank's Avatar
Originally Posted by rmfriday
what about a nxt?
Can you buy them with out the whole package (ie 700sci/NXT)?
thisistank is offline
Old 08-15-2010 | 08:35 AM
RMPRam's Avatar
Jon, I have an OEM Mercury installation drawings for performance products manual. The distance, along the crank centerline, from the back of the 1/4" rear motor plate to the inside of the transom on a motor with a #6 plug-in is 17 13/16". The distance from the same point on the transom to the rear of the motor on a Bravo boat is 8 1/2"
Gary
RMPRam is offline
Old 08-15-2010 | 02:22 PM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
Probably because $70K just for the legs is more than the cost for a pair of a new #6 much less Arnesons! Also, good luck dealing with a company that is not longer in business.
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 08-15-2010 | 02:33 PM
cougarman's Avatar
Gary
Gary,
Haven't had a moment to call yet.
So if you subtract 8.500" from 17 13/16 then the engine is 9.3125" farthur forward correct?
Thanks to everyone else for your imput also.
Jon
