MPH difference huber vs. crashbox??? >
Old 12-18-2010 | 11:28 AM
Default MPH difference huber vs. crashbox???
anybody swapped them out and left everything else equal???
302Sport is online now
Old 12-18-2010 | 03:10 PM
We did a swap from a velvet 71 c modified with more clutches to a crash box ,it was on a single engine 28 ft boat with a 750 HP BBC blower engine ,we could not see any difference at all ,no rpm /speed gain nothing
stirling is offline
Old 12-18-2010 | 03:45 PM
What was the weight difference?
blackboat is offline
Old 12-18-2010 | 03:46 PM
glassdave's Avatar
Neno the mind boggler
I think its largely reliability that you gain from the crash boxes. Pretty much indestructible.
08 OPA High Points Champion
glassdave is offline
Old 12-18-2010 | 10:37 PM
Comanche3Six's Avatar
On the Huber side would be dockside manners, on the crashbox side (as GlassDave pointed out) durability. I would think powerboat speeds would remain equal between the two.
Comanche3Six is offline
Old 12-19-2010 | 12:11 AM
I have no evidence to back this up but i have been told a normal transmission robs 100hp more from a motor when compared to a crashbox (in this example behind a 950hp blower motor). no idea how that translates to differences in speed
nate is offline
Old 12-19-2010 | 12:52 AM
I can't see that being the case. To the best of my knowledge a trans usually only eats about 35Hp. Boat transmissions are pretty basic, especially compared to automotive transmissions with multiple gears. You really think a Corvette or Mustang stick has an extra 100hp over an automatic?
Everything I've seen and know suggest that it's only about a 25-35 hp loss to run a transmission. A crashbox is going to eat something, but given that the total loss is 25-35 the difference in Hp loss is going to be minimal.
wjb21ndtown is offline
Old 12-19-2010 | 01:16 AM
We did not weigh both to see the difference ,but out of my head I think the crashbox is 20-25 lbs less
stirling is offline
Old 12-19-2010 | 10:25 AM
Steve 1's Avatar
If it has a cooler then there is a power loss,via friction generated heat.
Steve 1 is offline
Old 12-19-2010 | 10:57 AM
Steve 1 - very astute remark
If it makes enough heat to need the oil cooled it's taken some Hp to make that heat - the more cooling the more Hp - good analogy!
HabanaJoe is offline
