38 Top Gun TRS to BRAVO change >
Old 02-22-2011 | 09:37 AM
SpeedDoc's Avatar
Charter Member # 302
Noooooooo Bravoooooooooo. Huge waste of time and money swapping to a Bravo setup. You could probably find speedmaster lowers for your trs's if you tried.
SpeedDoc is offline
Old 02-22-2011 | 09:53 AM
cigrocket's Avatar
Only Speedmaster lower that bolts to a TRS Upper is the SSM II and no parts available and not stronger then TRS. Go Konrads or stick with TRS. TRS good for 600 HP. I had a flat bottom Cigarette Mistress with 675 NA motors. Ran 80-90 hours without failure. Then went Konrads.
cigrocket is offline
Old 02-22-2011 | 10:23 AM
DON'T DO IT! TRS's are much better for a big heavy boat like that. If you really want an upgrade go konrad, or as Rik would recommend, Arneson. Brovo's would be a major waste of resources on that boat.
RT930turbo is offline
Old 02-22-2011 | 11:28 AM
axapowell's Avatar
Where To
Default Konrad drives
Call Cary @ (315) 382-8828 he is looking to put a set of Konrads on his boat.
axapowell is offline
Old 02-22-2011 | 01:44 PM
What's the new hardware cost to go from TRS to :
Arneson drive conversion including props ?
Konrad drive conversion including props ?
ed
Interceptor is offline
Old 02-25-2011 | 02:20 PM
Look in the classifieds, there are set of Konrads in the Swap shop, that only have a few hours on them.
the conversion is easy, and that set is very reasonable everything there.
I would never switch to a bravo on a 38, too heavy for a weak drive. not to mention too much work, and poor balance once complete.
When I read through the tech section and see so many posts of people looking for a bravo solution it makes me wonder why others want to switch to them?
delsol is offline
Old 02-25-2011 | 02:22 PM
and as said above trs is a better drive than the bravo, to begin with. they are good up to 600 hp.
delsol is offline
Old 02-26-2011 | 08:42 PM
alot of top guns have bravos....i switched my cafe to bravos with 700s not that hard to do and boat ran great 5 years and no problems with the drives...whatever you decide get new gimbles
caferacer is offline
Old 02-26-2011 | 11:59 PM
DirtyMoney's Avatar
http://www.offshoreonly.com/classifi...o38279-en.html
DirtyMoney is offline
Old 02-28-2011 | 07:09 AM
This looks like a great deal. You will not find them cheaper. "Plug and play" and peace of mind.
frickstyle is offline
