Airplane People
Old 03-18-2011 | 07:36 AM
ZXXX Donzi's Avatar
Originally Posted by RunninHotRacing163.1
a grease zerk remove it and you'll find grease behind there
Yep, you will see them on lot's of things.
For a second I thought he was talking about and rams. I was thinking that those would make some mean flap actuators for your average Cessna.
ZXXX Donzi is offline
Old 03-18-2011 | 07:42 AM
SpeedDoc's Avatar
Charter Member # 302
It's a Bleeder, Just like the ones on your Calipers for the brakes on your Van. It's at the higest point in that hyd system (where all the air would be)
SpeedDoc is offline
Old 03-18-2011 | 08:03 AM
yes "zerk" thank you.....
pullmytrigger is offline
Old 03-18-2011 | 09:41 AM
Looks like I should start a poll.
I would love to throw a wrench on it and pull the zerk out but being they are over 40 years old I am a little afraid it will break off and then I am jacked.
If its a bleeder, the trim pumps pull all the air out by their selves.
If it grease though, for something internal......
got to figure it out. May have to take the risk and throw a wrench on it.
f_inscreenname is offline
Old 03-18-2011 | 10:08 AM
JUST DO IT !!!!!! and get the grease gun ready sooner or later that pins gunna need it especially with the H20 environment ... i gotta buck $ sayz Zerk
Old 03-18-2011 | 10:50 AM
The top pin doesn't get greased. Or at least it doesn't now. The pin in the top of the ram is pressed in. The two angles on each side let the pin move. No grease would go to those pins no matter how much I put in it.
Old 03-18-2011 | 11:18 AM
zooming in on your 3rd pic looks to be a sleeve on top where the pins pushed thru ... if its solid and pressed pin how is it being lubed to pivot when you run the tab ??
Old 03-18-2011 | 11:48 AM
Not sure if they were worried about that when they built the raceboat 42 years ago. This boat was supposed to last a season or two at most. You may be looking at the original prototype of "rocker tabs" here.
I've only had a couple trim tabs over the years but never saw where any of them needed the pins greased. Just like you don't grease the pins on an outdrive (at least Volvo's). The water takes care of that.
PS no sleve in
Old 03-18-2011 | 02:04 PM
Not much help but i know cessna did make hydraulic pumps at one time. (had one fail on a 73 Massey Ferguson tractor)
Expensive sucker too, maybe b/c it said "Cessna" on it.....
endeavor1 is online now
Old 03-18-2011 | 09:10 PM
99fever27's Avatar
I gotta buck on bleeder......remove it and you'll find hyd. fluid..
99fever27 is offline
