merc 454 fuel pump
Old 03-20-2011 | 03:22 PM
Wink merc 454 fuel pump
I want to add a low pressure fuel pump to my 1997 454 mag to stop the vapor lock issue. Is their a kit that they sell that has all the goodies? I know you need to have a oil pressure cut off switch. Problem is fuel injections starts off with fuel pressure in the line like primeing and if the low pressure pump doesnt start until it sees oil pressure you would have to crank for a while for the motor starts. Would like to avoid this.
IROCKET76 is offline
Old 03-20-2011 | 03:37 PM
JWoolever's Avatar
Is this what your looking for?
File Type: pdf
JWoolever is offline
Old 03-20-2011 | 08:26 PM
If you are running E10 ethanol, stop running it and use the 87 octane. This eliminated 99% of my vapor locking.
Do you have a VST system or Cool Fuel????
Griff is offline
Old 07-06-2012 | 12:32 PM
Default Service Bulletin
Thanks for the information.The check valve kit is what my dealer is saying I need to install because I have the cool fuel system with just the electric fuel pump.Will install it in the morning and see what happens.It's going to be 104 tomorrow.Fingers crossed......
Hank36 is offline
