KE Valve Covers CURE????
Old 04-27-2011 | 10:04 PM
Strip Poker 388's Avatar
Rob
Is this the Real KE or Hardin KE valve covers?
I can understand using the painted/coated valve covers etc,finish holds up, because the polished ones like mine are tuff to keep shinny.
Felpro makes a valve cover gasket that has the metal core and soft rubber/blue. also for OEM truck valve covers that will not leak.
I kept it simple
http://www.offshoreonly.com/forums/g...wer-motor.html
Try Chris Straub /OSO member with Steff's/B&B products, cast valve covers,http://www.straubtechnologies.com/
My Chevelle's B&B valve covers are 31 years old
If a valve lash all of a sudden needs adjustment, didnt some move/wear/etc? I can loosen my header and lay it over about 2 inches and I can get to the valve cover bolts and the covers come right off.
Strip Poker 388 is offline
Old 04-27-2011 | 11:25 PM
BattleCry's Avatar
Originally Posted by nitrousnolan
I could give a chit who it is, KE-Lighting whoever, all I know is I paid $1000 for a pair of covers that out of a total re-rig and NEW POWER are the only things making a mess!!!! Problem at hand is I spent $$$$ for a product that does not work and on top of that has a NEGATIVE effect on my investment. And the reputable "KE" does not give 2 chits!!!!!!
Well, you must give a Chit because, you are on here with a pair of $1000 valve covers that leak. So, I took a little time of my own and drove 35miles north to see Keith Eickert, the man, to ask him directly about your problem. Keith Eickert Performance Products is just a name that is owned by CP Performance/Hardin Marine. Please research back about 8 years ago to find out how KEPP was acquired. The KE Valve Covers, that CP Performance/Hardin Marine sells, are manufactured cheaply in China. Keith told me, that, along the top and bottom leading edge, that seats to the head, can fluctuate between .010 to .020 all the way across. Keith Eickert, along with Don Onken, operate and own Lightning Performance Group and manufacture the exact same valve covers, that are made to exacting standards right here in the U.S.A.
It was noted, by JoeD, that he had a set from 2002 that didn't leak at all. That was because they were still manufactured by Mr. Keith Eickert then, before CP Performance/Hardin Marine.
You can call and speak to Keith or Don anytime during the day to back up my claim at (309) 562-7271 or at www.lightningperformancegroup.com
Who did you buy the valve covers from?
Big Andy
BattleCry is offline
Old 04-28-2011 | 04:24 PM
Mine leak, but I stopped that by running a thick bead of RTV around the inside of the base, then tightening the cover down onto it. Let it set up and boom, no more leak. It was pretty annoying to have to explain that drip line of oil to everyone.
Philm is offline
Old 04-28-2011 | 06:43 PM
nitrousnolan's Avatar
AMEN
nitrousnolan is offline
Old 04-28-2011 | 09:37 PM
LapseofReason's Avatar
Well on my NT witch had tripps and was a pain to work on I just had 2 real long bolts that I would screw in the front and year of the exhaust and slide it out of the way and pop the cover off and slide it back, never have to lift it. No leaks, bolts cost 3 bucks.
LapseofReason is offline
Old 04-28-2011 | 10:28 PM
HotPursuit's Avatar
Ok this is the million dollar solution!! Its the o ring grove thats cut to deep!! Use a feeler gauge once you install the cover about .010 thick and stick it between the cover and the rail!! If it slides in with no problem the o ring aint doing Chit!! Take the cover off after marking the low spots and install pinstripe tape in the grove to tighten the low spots!! Install the o ring and some Ky and your set!!
It works perfect!! Bingo a dumb coonass solves KEs leak problem!! Your Welcome
HotPursuit is offline
Old 05-02-2011 | 06:54 PM
LPG
Default The Solution
The Lightning Performance Group 2 piece valve cover is the only solution to have easy valve adjustments and no leaks. 100% made in the USA.
Attached Thumbnails KE Valve Covers CURE????-web-pic.jpg   KE Valve Covers CURE????-valve-cover-web.jpg
LPG is offline
Old 05-03-2011 | 08:53 AM
Panther's Avatar
Frank's Marine Service
On a Poker Run it is way quicker and easier to pul an KE cover the make a quick adjustment or a fix if need be and yes we carry the spare parts, ya never know. As far as pulling the exhaust thats a great waste of time with the short season and amount of good weather we have here in NY. With the investment in the NEW power why start cutting cost on a cheap valve cover (unless you knew these would leak?). Just my .02
No worry's, I'm usually the one other people are asking to fix their boat at the poker runs.
Panther is offline
Old 05-03-2011 | 12:00 PM
Do you take trades?
Old 07-18-2011 | 02:28 PM
Originally Posted by In The Pink
Here is a photo of a repaired set. These are not mine. Just mill the bottom edge at 45° as to let the oil flow down and not build up and flow over the side and down your exhaust. I would think smaller notches would work just as well.
Guess I'm the 2nd one in a million to have leaking KE covers..... I also have KE headers so the KE valve covers come in handy when it's time to get to the valve train.
Nolan - that's exactly what I did to my KE valve covers. Got the idea from Sutphen30 on Boatfreaks. Got mine in '07 or '08 I think, and they leaked like a bidch. I called KE (CP?? don't remember now) and they offered to send me new bases if I sent the old one's back. Screw that, I figured if there's no design change, the covers would still leak with the new bases, so why go thru the shipping back and forth BS. I used a single flute carbide bit then a 150 grit (or so) drum in my cheapie Sears elec die grinder to 45 the edges of the bases, and no more leaking... period!!
You'd think KE (or whoever) would just take peoples schidt bases back and mill them as seen in the pics. Took me an hour or so. If KE set up a machine to do it, it would prolly only take a few minutes, and they'd avoid the bad press. Still have some oil and stains in my FRESHLY EPOXY PAINTED bilge from the KE covers leaking. And still pisses me off every time I lift the hatch.
Kidnova is offline
