#6's and speedi-sleeve
Old 05-04-2011 | 07:58 AM
Default #6's and speedi-sleeve
We have 3 sets of #6 drives (2 dry sump) that might need shafts; there's nothing wrong with the shafts except wear at the seal surface.
Instead of replacing #6 prop shafts because of wear at the seal area has anyone used the speedi-sleeves from SKF?
http://evolution.skf.com/zino.aspx?articleID=15297
If that won't work what are some options?
Dueclaws is offline
Old 05-04-2011 | 08:19 AM
Ryan Beckley's Avatar
Racer
Racer
I know that Craig Colabella has used them on our outboard gearcase quite often.
Ryan Beckley is offline
Old 05-04-2011 | 08:25 AM
Thanks Ryan: I believe that's a good example.
I seem to recall that's what Craig told me when he dry sumped the 6's. Do you have the current contact info for Craig? His web site is not active.
Dueclaws is offline
OldSchool's Avatar
Craig put them on both of my #6's two years ago when they were gone through. No issues and it beats the chit out of buying new shafts!!
OldSchool is offline
Old 05-04-2011 | 08:27 AM
Thanks!
$$$$ pricey shafts!
Dueclaws is offline
Old 05-04-2011 | 08:46 AM
Number 6 shafts dont seem to last especially in salt water.
A bunch of guys who do 6 work can install the sleeves.
Pro1 is offline
Old 05-04-2011 | 09:32 AM
Racer
Racer
Colabella Performance 407-498-0094
Old 05-04-2011 | 10:04 AM
Thanks. I left a message for Craig
Dueclaws is offline
Old 05-04-2011 | 02:11 PM
Panther's Avatar
Frank's Marine Service
You can do a speedy sleeve or have the shafts ceramic coated.
Panther is offline
Old 05-04-2011 | 04:05 PM
Thanks: hadn't thought about ceramic.
Once again JT @ TNT came through and was a huge help with the speedi sleeves. Thanks Johnny!
Dueclaws is offline
