Fastest single engine boat? Lets hear it!
#122
At one time yes.. 440 ci I believe. Current owner's setup ??
Arneson Surface Drives www.arneson-industries.com
#123
Oh so the boat has since changed hands?? Thats a big small block...Just curious, we have a little build going on to try and run that 100 mark, but it is always a plus to see a similar set up doing it already.. Def sounded like it had a procharger on it.. Thanks
John jr
John jr
#124
And for those that say they're going 20 MPH faster than you - except you just whupped them - my sister had the ultimate line back at the launch ramp once. We'd just totally walked away from a 24 Outlaw who claimed he was doing 86 MPH. When he asked how fast I was going when I passed him, Amy just said "Faster than you." Oh, hurts so good! (I'm doing 76 on GPS.)
Mine is a 97 28 Eliminator Eagle XP. 509 Whipple 6psi, aluminum heads, basically stock motor with XR upper, IMCO SC 2" shorty lower, 30 lab bravo. It runs 80 on about any day and 82 with the right wind/gas/payload.
#126
The new owner?? i think Scott pearson owns it not or at leaste thats where i saw it last in some pics that were poseted..
another sick video of him..the boat only had forward gear and direct drive..
http://www.youtube.com/watch?v=1jKhIXJ0fME
#127
mighty mouse has a 440 cid EFI small block with a procharger,,rumor is it could produce over 1000 hp but i think he had it tuned somewhere around 800 hp..
John jr
#128
The boat was direct drive, no transmission. George said if you cannot dock an 18' boat by yourself you should not be boating. Chris Allard purchased the boat from George..
#129
It made a bit over that on the dyno but in the boat the belt would not stay on in that setting, hence the 850 setting. At one point George was stuck at 103-104 @ 5,500 rpm ish. I asked him what the motor dyno'd at rpm wise and he said 7K so then run it up!! 113 mph then 120 then 124 at 6 something thousand rpm.
