Regarding the worsening Ethanol Fuel situation - a DIY solution
Good luck with that, I blew a Snowmobile up that was jetted safe 6 miles after filling up in the UP of Mi, went back and tested the gas there too the next day, crap was watered down, phase seperated garbage, talked to a Lawyer, said bring him 2500$ and he would file suit, he sent a nasty letter to this independent,never got a response. I avoid that place now like the Plague, I try to never buy gas from small town low volume stations any more and I do test the stuff often. I mentioned this Trout Lake Mi gas station on a Snowmobile forumm and I wasn't the first guy to blow up after gassing up there!!!! Smitty
Last winter a few of my friends had their two stroke snowmobiles burn down. These sleds were maintained well etc, etc. We started thinking about the ethanol levels prompting a call to two refineries. I spoke with a chemist at each company asking specifically about additives to mitigate these effects.
Long story short there are none. While neither one of the employees would say for sure that these additives are "Junk" they did say that the biggest problem with ethanol fuels are phase separation. Simply put when ethanol in the fuel absorbs all the water it can (Saturation) any additional water will cause the water/ethanol mix to separate from the gas lower the octane level at least three points (I was told likely more).
I was told that fuel ought to be used in a two week period. If stored, use stabil (Helps, not a cure). If in amrine environment drain the tank. I know its contrary to what we all have been told in the past.
Common sense regarding additives, if one were the magic bullet, it would have mobil, bp etc. on the bottle and sold at every station. Ethanol is detrimental to ALL of our hobbies.
I was also told that it will not increase higher than 10% due to auto manufacturers not having fuel systems that will survive.
Maybe this kit is a slightly easier version for what Smitty was talking about??
Looks like it's expensive enough and apparently you pay that much per sample so maybe you try to buy your boat fuel at one place only and say maybe sample it once a month??
I dunno -
http://www.fuel-testers.com/order.html
I dunno -
I dunno -
I dunno -
Mercury marine sells a simple to use ethanol test kit for under $10.00 if I remember correctly. You put a small amount of gas in a vile and add a small amount of tap water, wait a couple of minutes then read the scale on the vile for percentage of ethanol.
I did do a search and there seem to be a few going but no results posted.
Put your best foot forward!
Its actually the petroleum industry that gets the hand outs, even at $100 a bbl. Count the ways: 1) they get the hundreds of millions of years it took for oil to form for free; 2) they get the hundreds of billions of dollars per year required for military protection of the global supply chain for free; 3) they get the global climate change effects for free (everyone will pay an awfully large bill soon for this); 4) they get the global distribution infrastructure (harbors, pipelines, trains, roadways) for free; 5) They get the oil itself for essentially nothing (the leases are essentially free); 6) They get to pollute the ground water for free (everyone else pays).
In other words, the petroleum industry is very similar to the financial industry in its privatization of profits combined with the public bailouts for liabilities. Its really hard to get further from free enterprise than with entrenched energy.
Strike back. Buy stock in the oil companies and collect your share of the profits.
The thing is, without subsidies, the only fuel sold would be ethanol! Ethanol without any subsidies of any kind, including all costs (such as land and the fact you've got to invest in growing it for a long time before you can make it and then it still takes awhile before you can sell it) COSTS ABOUT $1.10 PER GALLON in the tanker truck driving to your local gas station.
And that is, by the way, the subsidized price.
