Cockpit construction
Old 12-09-2011 | 12:50 PM
  #251
glassdave's Avatar
Neno the mind boggler
Originally Posted by Gripenland
What type of accident would generate the most force on a cockpit?
Stuff?
Flip?
High speed roll?
snap roll or trip of to one side.
08 OPA High Points Champion
glassdave is offline
Old 12-09-2011 | 01:29 PM
  #252
Steve 1's Avatar
I agree and the complete cockpit assembly with canopy, has to be able to resist the highest speed (water pressure) the boat will ever achieve AND with a safety factor, the cockpit loading spherical 360 x 360 degrees.
Steve 1 is offline
Old 12-09-2011 | 07:32 PM
  #253
"from which a pilot controls the aircraft. Most modern cockpits are enclosed"
Lighthouse is offline
Old 12-09-2011 | 07:56 PM
  #254
Steve 1's Avatar
HUH ?? where was a open cockpit ever mentioned ????? This is 100% enclosed ,Rated and water tight!!!
Steve 1 is offline
Old 12-09-2011 | 07:59 PM
  #255
Originally Posted by Steve 1
...This is 100% enclosed ,Rated and water tight!!!...
Show Me!
Old 12-09-2011 | 08:07 PM
  #256
Steve 1's Avatar
Try post 234 and try to keep up !
Steve 1 is offline
Old 12-10-2011 | 04:52 PM
  #257
....and water tight!!!
A water tight cockpit will be very difficult to open if up side down due to the outside water pressure.
What is the best solution to this problem?
A secondary hatch in the tunnel will work for cats but not for v-hulls.
A valve to flood the cockpit in a controlled manner?
A tank of compressed air to increase pressure in the cockpit to match the water pressure?
Other solutions?
Gripenland is offline
Old 12-10-2011 | 05:26 PM
  #258
glassdave's Avatar
Other solutions?
Thats an interesting solution and certainly viable when you think about it. Also with a sealed cockpit breathing air will be an issue.
  #259
Steve 1's Avatar
Ok let's check the math: @ .44 PSI per foot sea water, Let's Say 8 feet down or 8 X .44 = 3.52 Psi, No big deal, Simply over pressure the cockpit or flip the boat back over. NO water in!!!! we are in a Drowning mess now.
Steve 1 is offline
Old 12-10-2011 | 05:27 PM
  #260
Steve 1's Avatar
Check Valve it!
Steve 1 is offline
