IS IT mpg or GPM ? ...
Old 01-01-2012 | 10:32 PM
Default IS IT mpg or GPM ? ...
..... at cruising speed ...what is yerr MPG ? ....and at WOT what is yurr Gallons-Per-Mile ? ...
ORE don't you care ?
MisterFiberglass is offline
Old 01-01-2012 | 11:16 PM
Stormrider's Avatar
JC Performance Engines
How about GPH?
Stormrider is offline
Old 01-01-2012 | 11:17 PM
At cruise I can usually plan on 2 MPG @ 3400 RPM, with 425HP 454's.
WOT I've never actually run the numbers, but it impacts my range significantly
RT930turbo is offline
Old 01-01-2012 | 11:18 PM
How about GPH?
About 22 GPH at cruise.
Old 01-03-2012 | 12:36 AM
I can get about 2mpg at cruise, so about 27-30gph. At WOT I dont lose much due to the massive speed increase offsetting the increase in consumption.
Philm is offline
Old 01-03-2012 | 06:29 AM
most people from what I see use gallons per hour. But from what I have seen move people at crusing get 2-4mpg.
soldier4402 is offline
Old 01-03-2012 | 06:47 AM
GPH Gallons per hour about 40!
Club Drew is offline
Old 01-03-2012 | 07:05 AM
Downtown42's Avatar
I don't care.
Why don't you read the same thread you started 9 months ago.
...or is-it gallons-per-MILE ?
whatchagot ?
http://www.offshoreonly.com/forums/g...ml#post3352839
Downtown42 is offline
Old 01-03-2012 | 07:26 AM
If your boat can be assessed in MPG, you are on the wrong site. We're focused on killing the environment using 16 cylinders at a time.
LaughingCat is offline
Old 01-03-2012 | 08:31 AM
3 MPG running 50-55 MPH
VetteLT193 is offline
