30's or 32's
Hey guys wanted to get some opinions!!
I have twin 553's naturally aspired engines currently running 30's @ 5700-5800rpm. I was thinking of running 32's to get better cruise speed and top end with lower rpms @5200rpm the differenece in hp is around 30hp less @ 5200rpm.
Are you running 4 or 5 blade? If 4 blade, you should give 5 blades a try. Something like the Maximus. Post this in the Prop section and see what Bblades have to say.
Not sure if this helps, but I was running 28p 4 blade hydos on my cig running 81 at 5300 with 500efis. I went to labbed 31p 4blade bravos with some cup and run same top end at 5000 and get on plane better and picked up a few mph at cruise.
