-   -   Leak proof, 10 yrs warrantee headers. (https://www.offshoreonly.com/forums/general-boating-discussion/268562-leak-proof-10-yrs-warrantee-headers.html)
Dean Ferry 01-11-2012 12:49 PM
Originally Posted by 737jetmech (Post 3591004)
Been running them on my engines for almost 10 years with no issues . Great design ... as you stated keep water in them they will last .
i ran my 1st set for ~8 years in salt water, flushed them everytime for a least 10 minutes, and never had a problem. Best Header on the market, IMHO:drink:
PARADOX 01-11-2012 02:04 PM
Originally Posted by Raylar (Post 3590718)
Pete:
Glad to hear about your possible new marine header product line. Just some thoughts and suggestions.
Please try and keep a few things in mind as you continue into designs and product of this class.
1. Headers should be headers and not just manifolds.The primary reason most performance boaters buy engines with true headers or add headers to their engines is to increase power. On normally aspirated engines the design and actual function of the header should produce measurable power and torque over a stock manifold or aftermarket manifold system. There is a science to actual runner shape, size and length and a true header should also have a carefully designed merge collector and transition into the tips to extract maximum efficiency from the engine. Todays performance boaters are very savy about performance gains and so you should have a header that produces results that will be verifiable in use and in the boat! There are actually only a small few marine headers that are excellent efficient designs!
2. There should also always be two distinct types of headers for marine performance engines, one long tube for N/A engines and another design specifically for supercharged and turbo charged engines the header requirement will be different especially how each engine type is trying to make maximum power.
3. Asthetics or "bling" in marine performance boats is HUGE, don't let anybody try to convince you its not that important!
Make sure the great looks are there as an aspect of your product and its design.
4. Try to keep the old saying KISS in mind. Keep the product as simple as possible and "Never Make a Product More Complicated than It Needs To Be to Work Well" !!
Keep the finished product easy to install as possible and easy to work on and service after install. Design in a clean finished appearance and tightly packaged as reasonable to keep space and clearance issues at a minimum.
5. Try to design and engineer from a market supported price point backwards to your final design and product. Its really not smart to design and then have to produce a product that is overpriced for its real market to a point where only a few users will purchase it.
I hope these ideas will help in your efforts. If I can be of help, let me know, I think I have a pretty good understanding of the marine exhaust connundrum and a lot of expierence into aspects of header design and performance.
Best Regards,
Ray @ Raylar
Thanks Ray
Your input and oppinions are allways welcomed and respected.
I got two things to work out. There is some "bling", it's shiny etc. but not as "clean" or polished for example as the CMI headers. I hate them (CMI) but they do look good and I can see this "look" issue is important.
I don't want to mass produce these, this is not my retirenment fund, more like a hobby and hopefully some will have a use for this. I want to keep the costs under $3500 per set and maybe a few hundred more to add some "bling".
The concept is pretty simple, but I have some dimensinal issues I got to work out for "side by side" apps. Cats, staggered, single.. no problem. I have a rectangular collectin box, (yup, i still need one). All the tubes are pretty much the same lenght, goes into the collection box all in line. (horizontal) No square box and no "upper" or "lower" ports where reversion and back wash is an issue. On the square boxes the two lower tubes always have some back wash or reversion issues. But I have to work out the side by side space. I think I got it figured out.
Thanks again Ray.. good stuff.
Interceptor 01-11-2012 02:08 PM
Paradox,
Do you have any idea of the costs to bring a reliable 10 year warranty product to the consumer ? You should design and test each application to obtain RAM data. You will need significant resources i.e. boats, engines, fuel, maintenance and many hours of testing.
PARADOX 01-11-2012 02:17 PM
Thirdchild
I gladly comment, and I have no porblems with any type of constructive inputs. That's why I started this.
In this economy may be the best time to offer something economical, that works. Not planning to get rich on this, it would be nice.. lol, but it seems we all keeping our boats longer. KE headers are great, costly to make, hard to get new sets. Plus, what I have in mind still differ from any casting style or full water jacketed system.
But let's think about one more thing. "Planned Obsolesence". I like Merc. but Merc has a plastice impeller housin gfor about what $50.? and a disposable impeller for about $20? so $20 protects 20-25K plus engine. Thats why there is aftermarket products that are better then the originals. (IE brass impeller housing)
My "gismo" :) while the performance would be the same as the top headers IT IS different in concept. may not be better, but that we just have to see how the consumers will react.
The air cooling was just an examle. based on the math, I got to get rid of so much BTU in the headers that the boat would go faster just by the air "jet" system out of the back.
I guess there is an out of the box "propulsion system" :evilb:
PARADOX 01-11-2012 02:33 PM
Originally Posted by Interceptor (Post 3591153)
Paradox,
Interseptor.
I don't see my design to be a mass market product. I hope I'm wrong and it takes off like wild fire, but.. this is more like a hobby and passion, not my retirenment. I will still have to work. It would be sure nice if I'm wrong and I can just quit my day job. :)
I want to keep the price down for a set under 4K.
I can do that for 500's 525's 600's, may be the 700's but for the 850+HP, just simply the material costs, being larger and "thicker' might go above $4500
I only want to make two types. Under 850 and above. the concept is the same.
Knot 4 Me 01-11-2012 02:41 PM
Give the State of the Industry, 2012: Part III a quick read. Bob Latham has some words of wisdom on the topic of bringing new products to the marketplace.
WildThing47 01-11-2012 03:08 PM
Considering I just spent 10k + to redo my headers/tails, and the cost of a motor if they leak severely....I'd be very interested...
PARADOX 01-11-2012 03:33 PM
Sorry buddy, can't help you. My amazing, revolutionary design can't leak. If you want something that "leaks severely",, you know where to go.
Just kidding, I think I know what you meant. Keep posted, and once I get some more feedback, work out a few glitches, etc. will see how it will sake out. :drink:
CDN 1 01-11-2012 04:54 PM
Stainless Exhaust
These are stated to have another 15yrs of Use, Tested ,,, left:eek:
Could use More styling But cover alot of Small Block apps.
E Bay #150734422685
28cigarettess 01-11-2012 07:20 PM
Originally Posted by offshoredrillin (Post 3590954)
pot meet kettle...:evilb:
:grinser010:
glassdave 01-11-2012 08:21 PM
E Bay #150734422685
Man . . . Those look like a high school shop project :D
PARADOX 01-12-2012 09:40 PM
E Bay #150734422685
Wooo hoo 15 years.. lol.. I guess i have to extend my Warrantee. ( or is it warranty? :eek: )
letterrip 01-26-2012 05:28 AM
KE's = Peace of Mind....!
8 seasons & never an issue.....!
scarab63 01-26-2012 05:40 AM
Thats what I was thinking when I read paradox first post....
No bling, no frills, heavy, reliable = ke cast manifold / headers
10 yr warranty......how could anybody say no to that? Does this include salt apps?
no hoops to jump thru? Heres my old ones, send me new ones!! if so that'd be worth it to me
Dean Ferry 01-26-2012 05:43 AM
Agreed, they are the best/toughest header out there. I have heard good things about IMCO Powerflow + also.
Dean
4bus 01-26-2012 07:43 AM
Salt will not matter, read above, he plans to cool with air ?
4bus 01-26-2012 07:47 AM
The KE are mentioned a lot in this thread, so I hit the link given earlier in this discussion....the headers are gone :angry-smiley-038:
Missing on this link
http://www.keitheickert.com/c-9-exhaust-systems.aspx
Dean Ferry 01-26-2012 08:29 AM
diamond marine is still selling them, although, it might be an old add.
http://www.diamondperformanceparts.com/home.php?cat=282
mr3dman 01-26-2012 08:31 AM
Personally, i've always wondered why the exhaust is water cooled at all. Materials are around that can keep the heat in check and are used all the time. Turbines use them, motorcycle mufflers, etc. Why use a water jacket at all when you can use a dry header. I imagine a cmi, or other stainless header with a heat barrier as the water jacket with composite cover for the hot spots like at the head or joints. Has something like this been tried? The through hull could even be made to act as a water dump to cool the exhaust and pipe as it exits the boat while capping it from going upstream. Am I off my rocker in looney land?
WildThing47 01-26-2012 09:19 AM
You could also coat them....most heat coatings now are pretty amazing...
4bus 01-26-2012 10:35 AM
Lot's of reasons. Our engines run very high EGT's all day long....all day. Drive your truck down the road at 4 grand while towing 20,000lbs with near flat tires, after 20 mins tell me if anything smells like it is burning. Do that all day every weekend
Most of our engines get the air from the bilge area, more heat, less power.
Exhaust would not be pretty for long running at 1200 degress all day, and will not last long if they got wet or salt on them at the temp. Imagine this under your hatch
http://www.fordification.com/myproje...set2_68-05.jpg
Air flow in the bilge, everything else has the advantage of some kind of air in/ air out cooling...such as the grill on your car, the cool air is deflected in (sometimes underneath no grill) and exits behind the engine.....how would you do this on a boat?
The cooling water is free, and cool. We all use it for a/c and generators. If this same cool free water was available on the road, you would see different technogly in cars. Snowmobiles use free snow and free ice cold air to cool their engines and exhaust.
cliff_m_b 01-26-2012 02:15 PM
@ PARADOX,
When will you have more info on this new exhaust? Will you have a provision to mount a turbo? If so I would be interested in two pairs for a staggered.
Cliff
mr3dman 01-26-2012 02:23 PM
I hear you loud and clear but if the heat is the problem then turbo's wouldn't work in a marine environment. Same goes for turbiines. I really believe it is possible with the technology we have today, it just hasn't been tried yet. With a thermal cover on a turbo you can touch it by hand, even after a hard pull.
4bus 01-26-2012 04:35 PM
Are the exhaust manifolds in a turbo engine boat still cooled by water? :D Yes a turbo car with a turbo directly mounted on the exhaust manifold is HOT to the touch, however my diesel ford turbo was plumbed from the exhaust, on top of the engine, and the hood did not even come with a heat shield....no heat issues at all. The turbo was warm after running, but not hot like bare headers would be. Comparing an oil cooled turbo to SS headers seeing EGTs from 1200-1300 degress is not fair. Exhaust headers or monifolds off a car would be furnaces in there.
Steve 1 01-26-2012 05:07 PM
A lot of the problem with Marine headers is the Material they are made out of.
PARADOX 01-26-2012 05:52 PM
A few quick answer to some of the posts.
The design/concept is not AIR cooled. That was just an example.
After the Miami show and once I further discussed this with "experts" I will provide more info.
The warranty is posible, since there is no possible mixing of exhaust and coolant.
Water, (fresh or salt, or what ever the way I get rid of the heat. :) ) can't get into the exhaust tubes, thus the engines are safe. That's all for now, more to come at a later date.
Thanks for the comments and interests.
P
mr3dman 01-26-2012 11:01 PM
ok, i'll yield my arguement. I am real curious to see what this is though. Any idea on a timeline on release of the product info or demo?
4bus 01-27-2012 11:26 AM
P
I'm all for it, but I agree with the statements about "bling" It is so important in this industry......unless you chase the cruiser market?
Make it better and make it look cool, you will have a winner!
IMO if merc doesn't make the 1350 prettier, they will lose
more market share to the other big guns.
Mastercraft240 01-27-2012 11:34 AM
I disagree..... I think you're finding more new boats using simplicity as their bling factor. Also, I'd rather have a "less blinged" out motor that ran everyday than a motor that spend more time in the shop then in the water. For example, the SVX40's OL and the new SV43.
4bus 01-27-2012 12:05 PM
Maybe that is the case, truth is I will never be in the NEW boat market, so it could shift and I wouldn't know :lolhit:
However, the biggest boat show in the US....the Miami boat show.....you're telling me everything will have a plain wrapper this year? lol
A 525EFI might look plain to us, but to the majority of boaters it has BLING! The 1350 looks like a 496ho.
Lot's of big money boaters out there that LOVE to open their hatches. Won't make much sense in the engines have plain plastic shrouds, and matt finish blocky exhaust
Mastercraft240 01-27-2012 12:08 PM
Of course im not saying that. You have a valid point about the 1350's.
Steve 1 01-27-2012 01:29 PM
The last I checked Mercury has a 4 month backorder on those 1350's Get used to them ,that is the future.
pqjack 01-31-2012 07:06 PM
are you telling me my 496 looks like a 1350??
yessssssssss...that's worth 50hp
4bus 01-31-2012 08:48 PM
I'm not sure what that means, that could be 2 units :eekdrop:
Seriously, love the concept of the 1350, and the warranty for that kind of power is unheard of. However, think about what they started when they painted the first 440hp blue. Then dolled up the 525SC, 600SC. The 575SCI with CMI's was blinging, then came the 800SCI and 1075SCI with CF....wow! I just expected a little more in the visual dept from Merc Racing!
4bus 01-31-2012 08:49 PM
I think the plastic schroud has the same bolt pattern :D
orthos1 02-03-2012 12:14 AM
Anybody use Stellings? I have a pair on my 525 in my Talon.
Interceptor 02-03-2012 10:27 AM
I'll take Plain Jane reliability over bling any day.
43sv 02-03-2012 10:50 PM
I have tested cmi big tube against stainless gen 3 5inch manifolds and they made 8hp more on a 1100 hp blower motor. No reason to deal with the inherent cmi problems, we all know how well they stand behind there products. You can deal with looks or leaks.
onesickpantera 02-10-2012 05:33 PM
The only issues ive seen are with the 525s because they were made to mercy's specs.
rexone 02-11-2012 04:36 AM
Originally Posted by Coolerman (Post 3590974)
Thanks Chris. Yes, my father designed and built them for 10yrs, and then sold it to Keith.
The first test set we built is over 20yrs old and has a god knows how many hours on it (the set is still in use today). The ones on our boat our 12yrs old. RmpRam had a set that he ran for over 10yrs I believe. A select few did manage to melt them, but it would have helped if they would have ran water through them or rigged their boat with something other than swimming pool hose :picard1:
Jason I remember your dad showing me those, had to be very early 90's at Miami Black Thunder booth I believe. A lot of folks poo poo'ed them back then. Go figure, they would emerge near the top of the heap 2 decades later as more reliable than ss tube. I always thought it was a very cool and functional design.
