Ilmor High-Performance unveils MV8 570 Small Block >
Old 03-13-2012 | 01:04 PM
  #91
Originally Posted by Raylar
I'm kind of thinking they may have been stating total weight with the Bravo(Teague) drive? My approximate calc + 585lbs engine +exhaust + bravo coupler and bellhousing + 225 lbs for bravo transom + bravo drive = approximatly 810Lbs.?
Best Regards,
Ray @ Raylar
You could be right! And yes, that would be a substantial weight savings for the smaller boats. My complete power/drive package (588/trans/ASD #7) weighs in just under 1,200 pounds. When I started my build, I first looked into having Mike build me a set of large ci small blocks, but the 200 pound per engine savings wasn't worth having to run high compression/high rpm motors to equal the horsepower of my pump gas/6,500 rpm 588s. IF this weight of 810 pounds is for the complete power/drive package, Ilmor has themselves a great new product for the under 30' boat market.........
Skater30 is offline
Old 03-13-2012 | 04:46 PM
  #92
The weight of the MV8 570 is 810lbs with dress, headers, mounts, bellhousing, and fluids. This does not include a transom/drive.
IlmorGirl is offline
Old 03-13-2012 | 04:59 PM
  #93
wrinkleface's Avatar
Originally Posted by IlmorGirl
The weight of the MV8 570 is 810lbs with headers, mounts, bellhousing, and fluids. This does not include a transom/drive.
U tell'm J!!!!!!!!!
wrinkleface is offline
Old 03-13-2012 | 05:37 PM
  #94
So please explain to me how Ilmor is claiming to be 400 pounds lighter than a comparable BBC? Again, my 800 hp 588 ci Sterlings are 855 pounds with the same equipment. That's only a difference of 45 pounds, not 400 (not to mention the 230 hp difference on 91 octane pump gas!).
Skater30 is offline
Old 03-13-2012 | 07:09 PM
  #95
Question
I guess whats got us all scratching our heads is how does 2+2=4 Eh! Well , I'm stumped!
Best Confused Regards,
Ray @ Raylar
Raylar is offline
Old 03-14-2012 | 02:04 PM
  #96
I'd really like to see this in a Tuff 28.
tabajay is offline
Old 03-14-2012 | 05:35 PM
  #97
rmbuilder's Avatar
MarineKinetics
Originally Posted by C_Spray
Bob, are the turned aluminum parts in the intake hoses sonic restrictors? Cripes, they're small...
Chuck,
Good catch! Interesting observation on the intake restrictor. In 2008 (LeMans & ALMS) trim the LS 7.0 liter engines were mandated (2) 31.2mm orifices, for a total intake area of 1529 mm². That’s 2.370 in² total (the approximate size of a half dollar each) of inlet area feeding a 427 cid engine. At that level of restriction the engine made peak TQ @ 4400 RPM, went into choke @ 4800 RPM, peak HP @ 5200, and carried to 6200 RPM. It made 580bhp @ 5200 RPM on E-10 and 590 bhp on E-85. Quite an achievement for an engine restricted to that degree.
Bob
rmbuilder is offline
Old 03-14-2012 | 06:05 PM
  #98
The stated weight is the engine only BUT is full of fluids ready to be dropped in. I believe other stated weights for some of the competition includes the whole package, WE DO NOT. This is a closed cooled engine with CMI headers. There is a good amount of fluids included in that number.
Should have some more info soon so stay tuned!!
ILMORdude is offline
Old 03-14-2012 | 06:43 PM
  #99
Wink
I forgot that this new LSX based engine uses the tall deck LSX IRON block and with all accessories, freshwater cooling and headers it indeed probably weighs about 800lbs. with a transom assy and drive it should still come in about 1025lbs and as such should be about 200 pounds or so under a HP565 that Mercury Racing is now offering. In a twin installation that could translate to 400+ pounds and in a 28-36 ft performance hull that could be a nice plus as well as the added rpms this engine will run at. In any event I know Ilmor will get the real total facts and data out for OSO'ers and I am sure this will be a great performer in the right applications.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 03-14-2012 | 07:26 PM
  #100
Best Regards,
Ray @ Raylar
Ray. I'm pretty sure the published weight of 1201 lbs. of the 565 package is without headers and no fluids in either drive or motor.If so, wouldn't the MV8-570 be closer to 250-300 lbs. lighter?
Btw. is the weight you calculated in a previous post, the weight of your 550 LS alu motor w/o manifolds?
A.O. Razor is offline
