Ilmor High-Performance unveils MV8 570 Small Block
#51
http://www.hotrod.com/techarticles/e...g/viewall.html
#52
From Ilmor's web site:
Introducing the Ilmor High Performance MV8 570
Ilmor developed internal components provide unsurpassed performance and reliability, including forged steel crankshaft, pistons and connecting rods
Hand-built to the same quality standards as our race engines and MV10 engines
87 octane compatible
Dual-equal hydraulic phaser that adjusts cam timing for intake and exhaust valves
Over 2" shorter and narrower than the 8.2L big block engines
570 hp @ 5900 rpm
564 ft-lbs @ 4400 rpm
10.7:1 compression ratio
High Performance Cast Iron Block; Cast Aluminum Heads
Unique Ilmor-designed custom cast aluminum upper and lower intake manifolds
Available Summer 2012
I stand corrected on the 803 pounds with drive. (Thanks, Nick.) Anyone know how much a Bravo drive/transom weighs?
570 hp @ 5900 rpm
#53
Just another thought for these fine Ilmor LSX engines- that is they are 400lbs less per engine than the Merc 565 and with 454 cubes of VVT high rpms they should be about 15% or so more efficient with respect to fuel burned per hours run. Might be a nice secondary benefit, especially when gas hits $5 a gallon or more!
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
#54
LS car engines do use VVT. Here's a good article on VVT.
570 hp @ 5900 rpm
570 hp @ 5900 rpm
#55
Hey can someone give me the short version of how variable cam timing works? Whats variable the lift? duration? both? how, some kinda funky rocker arm or lifter? what is its advantage or is the obvious manageability on the low rpm side and more everything on the top end. Just curious because i have heard it more an more lately.
08 OPA High Points Champion
#56
They have a phaser, a movable cam sprocket, that article refrenced above details it pretty good.
#57
Impressive numbers. The thing I like about the LSx platform, and the reason I chose to build a pair for my Magnum project, is the extra six hundred to one thousand rpm you pick up with that motor. That translates directly to prop shaft speed. Can't wait to see there drive, THIS is how you put together a competitive package in the marine industry. Slow steady pressure with smartly engineered products.
Sweet crate motor. Not that I would endorse using a GM crate motor for performance marine use.
#58
LSX454 http://www.gmperformanceparts.com/lsx/index.jsp
...or did I miss the intention of your
#59
