How fast MTI 40 with 525's ?
Top speed on a large cat with 525EFI's can get into the higher speeds. Just be prepared to hold the sticks down for a long time. The trick is to run smaller gear ratio's but keep the pitch up. As your slip comes down your speed can still hit those top numbers. A lot of the top number is based on the top RPM as well vs slip.
I know with Bob's race boat (368 Skater with BONE STOCK 525EFI's) has run just under 132 in a kilo but averages 115-130+ in normal race set-ups (depending on water conditions)..
I would imagine a 40' MTI (Awesome boat!) would get to 125MPH w/ 39's or 40's on it... This boat should have no problem getting down into the 8% slip or less on the big end..
Some people don't realize the difference between a boat set up for 525's vs. a boat with bigger power. It could be 2000+lbs, depending on the glass work and all the extra goodness installed. Weight placement can also effect the top speed.
140MPH is hauling ass even with big power, but it depends on how it is propped and set up. Honestly, would you rather had a boat that accelerated like hell to 140 or would you want something sluggish to 150? Either way your hauling ass but the acceleration is the fun part, because you are probably going to have an average cruising speed of 85-115? Boats are fun because you never really know what they are going to do until you get out there and do it!
I don't know if this makes sense or is on point, but my 2 cents -Eric
Hahaha, I'll kick you just to remind you.
I have always been impressed with the numbers they get out of Cat Lite, prop technology has really opened that door. Bob raced with us in OPA'a Class1 a time or two when we were still running 750 Supercat motors we couldnt catch him. Just out of curiosity are these top end numbers with crash boxes and if so what would switching to a shiftable trans do to top end?
08 OPA High Points Champion
Little Speed is a cool boat. Turn-key, reliable, lots of custom parts and you can still walk away from most V-bottoms. Ehh.
