How fast MTI 40 with 525's ?
#31
Very, very few boats have the recognition of Speed Racer. I can't imagine what it would be like to pull that boat down the road, let alone to have it on the water. The 525's seems to be a great mix of speed, reliability, and fuel economy. The dirtiest spot on this boat is cleaner than anyplace on my boat. I'd hate to see it leave LOTO, but I sure don't have the checkbook to keep it there.
#32
So here is a question. Why are the big cats, i.e. 368's, 388's, 40's, faster with 525's than a 30 or 32?
I understand that they have a lot more tunnel surface area, but they also have more weight and loads more aerodynamic drag. Does the tunnel size really make that much of a difference? What is the fastest 30, or 32 cat with 525's? I certainly cant say that I have ever read about any of them approaching 140mph.
#33
[youtube]http://www.youtube.com/watch?v=RGDNYdVhuZk[/youtube]
MTI running at Smoke On The Water Poker Run
Music sucks on this
I had used somthing more appropriate but You tube changed it
We did not have any engine sounds for this but you can see this boat hauling the mail. Got a little scarry for a minute
Music sucks on this
#35
Possibly someone can shed some light on me. When you use a "Prop Slip Calculator" and plug in the following values for calculating THEORETICAL SPEED of a boat running 525EFI and #6 drives:
Gear ratio - 1:50 (highest allowed ratio for racing orgs)
Prop pitch - 40P (maxium size pitch prop allowed)
engine rpm - 5600 rpm (rev limiter set on stock 525EFI)
In theory you get a top speed of 141 mph, with a 7% slip you would see an actual 131 mph. (if the boat was set up right on the money and ran perfect)
I don't understand how all these other " higher mph numbers" come out without changing one or more of the above variables.
I am willing to learn.
#39
Change in gear ratio is the usual culprit. I am pretty sure the ratios are as follows: 1.49:1, 1.35:1, 1.24:1 and 1.15:1 so you can see how it can be changed but as you go up in gears you will lose a lot of the punch. My boat has been 153 with 1.35's but with the 1.49's it's 10-15 mph slower but doesn't take 10 miles to get there.
