Skater Burns at Desert Storm... >
Old 04-25-2012 | 10:38 PM
  #61
HotPursuit's Avatar
Originally Posted by madhatter42
Is it me, or are there an awful lot of tragedies happening with boats burning lately, especially skaters...
Have these boats had the tanks redone?
I was thinking about this the other day....the tanks could be leaking causing fuel to go into the bilge...I'm not insinuating but I was thinking about this, this is exactly the problems that were supposedly going to happen if you didn't replace the original tanks in the Skaters....I only say this because in recent light of the accidents happening with Fire, and Skaters in the same sentence...they all seem to be older boats as well..
Just a thought...and my .02 c
I say blame the goverenment for putting corn fuel in fossel fuel !!There were no problems with anyones tanks until 10% Ethonal was added.. If your talking about the boat crash with David and Leon. Get your facts straight.It didnt blow up at the dock and the tanks were redone!!
Not many boats that I know of that you can run into a 8 ft high embankment and not blow up..
From the photos its clear that the fire started on the starboard engine.. Fire Suppressing would have save that hull. Shut the hatch and release the Co2 or any other no flammable gas..
HotPursuit is offline
Old 04-25-2012 | 11:32 PM
  #62
Steve 1's Avatar
Actually the tag on a gas pump should say warning; 10% contamination, since there is 10% Alcohol/brake fluid/paint remover in it, Alcohol is a bad dude.
Steve 1 is offline
Old 04-25-2012 | 11:39 PM
  #63
Originally Posted by Raylar
I might be interrpeting the pictures incorrectly, but it looks like the hatches were open, the engines were not running and that person was busy removing the cover just as the fire started.
My guess is he had just probably turned on the battery switches when something electrical might have shorted, started an electrical fire that burned quickly into a fuel line, possibly under fuel pressure and Vroom, there goes a ragging fire. This may have been a case where fuel fumes where not the culprit but battery amperage and a bad short. Just surmissing here but the hatch had been opened and he may have already smelled for fuel and such and the bilge blowers may have even been running, who knows?
In any case it is very sad when a boater looses his boat to a tragedy like this and the only good part of the story appears to be that no one was injured. From those pictures if that boat had had a successful launch and was loaded with persons and was leaving the dock when the fire broke out, the situation could have been a lot more tragic!
Best Regards,
Ray @ Raylar
ray,i agree,looks like electrical problem might be the culprit.
mike tkach is offline
Old 04-26-2012 | 06:37 AM
  #64
Good chance that the hatch was laying 30 feet away.
thirdchildhood is offline
Old 04-26-2012 | 07:38 AM
  #65
Audiofn's Avatar
Charter Member #232
Best Regards,
Ray @ Raylar
That is how the fire started on my Hydrostream a bunch of years back. This thread reminds me that I have to fix my blower motors before I drag the boat up to Maine. Very sad to see that happend to anyone, going to be a long drive home. I hope some one has some room for the guy to run with them.
Put your best foot forward!
Audiofn is offline
Old 04-26-2012 | 08:06 AM
  #66
Hatch is open and still attached to the boat according to pics. Bad deal any way you look at it
Drock78 is offline
Old 04-26-2012 | 10:42 AM
  #67
WildThing47's Avatar
**** happens on these things, I was just trying to make a comment and I specifically said I do not want this turning into a who said who, just a simple, "hey, this was an issue, is it realted?"
WildThing47 is offline
Old 04-26-2012 | 11:29 AM
  #68
fountain4play's Avatar
Originally Posted by notda1
I don't think a fire suppression will work with the hatches open , I had one put out a fire in my engine compartment a few years ago . I belive it suffocates the fire , but not positive
You are correct the clean agent fixed type of extinguishers are designed for "Total Flood" which requires that the space be as sealed as possible (Hatches Closed). This type of pre-engineered system is designed to protect a certain volume which is listed on the system cylinder. They are very effective with a flamable liquid or electrical fire but won't do much if you have an explosion. Once the hatches are open and a fire starts the only option then is to use the portable hand held extinguisher.
The one drawback to this type of Automatic fire suppression is that they are actuated via a fusible head on the cylinder valve which requires a fairly high temperature to set them off.
Some models also include a Manual Actuation Lever that is either electrically or mechanically operated that will discharge the system when operated. Most boat manufactures only supply the Automatic style without the manual actuation.
This is another reason that a good quality hand extinguisher should be within the reach of the operator in the event of a fire in the bilge.
fountain4play is offline
Old 04-26-2012 | 08:39 PM
  #69
Panther's Avatar
Frank's Marine Service
I feel bad for the owner. That's a crappy way to start the event.
It could have happened to anyone, I don't care if you're Mr. safety expert.
Panther is offline
Old 04-27-2012 | 10:51 AM
  #70
Originally Posted by mike tkach
my buddys think im crazy,but every time i put my boat in the water,i always open the hatch,turn on the blower and smell for gas fumes,then i start them and check for leaks,only takes a minute,and if nothing else,it gives me peace of mind.electrical fires can be almost as bad as a gas leak,but probibally less common.
+1
rkroupa is offline
