bravo question
Old 05-07-2012 | 09:12 AM
Default bravo question
Can you have the engine running and put the drive in gear if you have the boat out of the water ?
emp23nordic is offline
Old 05-07-2012 | 10:17 AM
As far as I know you can, as long as you have the muffs on it, and the hose out of the way.
Of course, you will have a prop spinning around which could be VERY dangerous!!!!
I have done this myself though...no problems noted.
Drivehard is offline
Old 05-07-2012 | 10:22 AM
onesickpantera's Avatar
Do it every year to make sure everything is working properly.
onesickpantera is offline
Old 05-07-2012 | 11:19 AM
Yes.
Griff is offline
Old 05-07-2012 | 11:24 AM
Dave M's Avatar
Veteran: Navy
I do it too. But, never advance the throttle past idle.
Dave M is offline
Old 05-07-2012 | 12:59 PM
Thanx for the replys
Old 05-07-2012 | 01:00 PM
yup I do it too, but never start without water, I wouldnt go back past idle like said above.
soldier4402 is offline
MnFastBoat's Avatar
Charter Member#157
Like to add,
Remove the prop!
Unless your the only one around!
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 05-07-2012 | 02:46 PM
also if you want to try reverse and foward make sure you do a long pause as that shaft will spin freely even after disengaged, best to even eyeball it to make sure it stopped before going in opposite direction
88242LS is offline
Old 05-07-2012 | 04:42 PM
Do not run without water source! Even for very short time. If you have done this already you may want to consider changing the impeller before your next adventure out.
relaxalot is offline
