Rod Bolts...
Old 05-22-2012 | 07:06 PM
Rottiguy's Avatar
Default Rod Bolts...
Why do rod bolts break? Only 3 hours on new power and look at the pile of junk I'm left with. Is this common? Is it just one of those things that happen with blower motors? The new builder said he saw no signs of excessive heat or oil problems.
Attached Thumbnails Rod Bolts...-2012-05-16-11.44.53.jpg   Rod Bolts...-2012-05-22-19.50.21.jpg   Rod Bolts...-2012-05-22-19.50.34.jpg
Rottiguy is offline
Old 05-22-2012 | 07:13 PM
blue thunder's Avatar
Man, sorry about that carnage. Over torqueing the rod bolts can surely cause that problem.
blue thunder is offline
Old 05-22-2012 | 07:24 PM
Default fixx
from the looks i would say that was not from a rod bolt breaking,,looks like the rod gave out first then from what was left of the rod beating everything it could is when the rod bolts let go..how much boost? almost looks like that cylinder was hydro locked from too much fuel or water,pressure test the exhaust..
? what does the rod cap look like and the crank,any bluing on the journal?
FIXX is offline
Old 05-22-2012 | 07:32 PM
aquaforce's Avatar
Well I will be sick if my engine goes at 3 hours. I still haven't got to dyno yet.
aquaforce is offline
Old 05-22-2012 | 07:45 PM
Rottiguy's Avatar
5 lbs New builder said the tune looked perfect, Stainless marine manifolds are arent leaking. Water pressure was 15lbs. I dont have any pictures of the crank, but it wasn't to bad. I was told it could be polished and used, but I just ordered a new one anyway.
Rottiguy is offline
Old 05-22-2012 | 07:48 PM
Rottiguy's Avatar
Unhappy
Yeah its a pretty bad feeling. I thought I had good parts, but the old builder said I had the Callies Chinese rods
Rottiguy is offline
Old 05-22-2012 | 07:53 PM
Rottiguy's Avatar
more pics
Attached Thumbnails Rod Bolts...-2012-05-22-20.41.00.jpg   Rod Bolts...-2012-05-22-20.41.17.jpg
Rottiguy is offline
Old 05-22-2012 | 07:59 PM
How fast was it spinning when it let go?
fastdonzi is offline
Old 05-22-2012 | 08:08 PM
Rottiguy's Avatar
5400ish
Rottiguy is offline
Old 05-22-2012 | 08:14 PM
I did this once.....
O N C E......
Plastigauge and mixed two up. (6/8).....
It started screaming at about 3500 on the first pull.....too late.....
That rod was either meant for another hole, or it had NO oil...that cap is bluuuuuue
Sucks bad, I know. I think I'm having a bit more of an in-depth discussion with the builder.......
commandersander is offline
