Starting Engine with no Water??? >
Old 05-25-2012, 02:06 AM
did it on the 496 all the time,,ran it for 10 seconds only,,,it also had electric fuel pumps,,remove belt also
TWIN-SPINS is offline
Old 05-25-2012, 09:59 AM
The impeller in the pickup for the water pump in your lower unit will get fried.
Ask me how I know....
BajaGTO is offline
Old 05-25-2012, 11:18 AM
not sure what you guys are doing to fry impellars but i have done this numerous times with no issues. actually, early in the season if i know there is risk of freezing, i will pull the plugs and start the motor for 10 seconds. give it a couple of burps and kill the engine. this ensures most of the water is out of the engine.
keep in mind there is quite a bit of water in the blocks and cooling loop when you pull the boat out of the water. this should provide enough lubrication to run for at least 10-15 seconds. you obviously cant do it repeatedly as the water is discharged on the first start.
1MOSES1 is offline
Old 05-25-2012, 11:30 AM
It costs $10-20 bucks for a set of muffs and you can run it all you want. The risk benefit on that decision is hugely lop sided.
Captain YARRR is offline
