29 kryptonite speed/setup questions >
Old 06-12-2012 | 06:27 PM
Default 29 kryptonite speed/setup questions
hey everyone i have a 29' kryptonite with a 650hp 548 bravo xr with the stock dwp lower and bravo 1 28P with some pitch added.
it runs the best of 93.8 at 6000 rpm light on fuel and usually runs 90-92 at 5800-5900 with more people and fuel.
you guys think id benefit with an imco lower.. possible shorty and or a different type of prop? hydromotive etc.
thanks!
ray pampena is offline
Old 06-12-2012 | 06:39 PM
TeamSaris's Avatar
Driver-441
Racer
Your teetering on the needing a nosecone/not needing one speed but It might like the higher X-Dimensions, Kryptos seem to. Not an ITS right?
TeamSaris is offline
Old 06-12-2012 | 07:32 PM
What is your X now? I seem to remember my prop shaft about 2 1/2" below my bottom. That worked real good.
jdub is offline
Old 06-13-2012 | 12:16 PM
no ITS.. ill check to see where my prop shaft centerline is after work. id like to do something to get a little more out of it but id hate to do a lower and get no results.
what prop type are you guys running? think id do better moving away from the bravo 1?
Old 06-13-2012 | 02:04 PM
What ever Fast Fun 2 tells you should be Golden, I believe they have one and have wrang out every last bit of speed from it (Thats what they do )
But, if the 29 Fountain ( Watch Your Back) and the new 29 Outerlimits are any indication of how high your X dim can be I'm sure you still have room to go up, They are very high and achive Great speed, Both have Shorties.
fastdonzi is offline
Old 06-13-2012 | 09:22 PM
Ray, ask skip to make your bravo into a -1 shorty. It'll most definitely help and be cheaper than buying new!
Mastercraft240 is offline
ok, my prop shaft is 3" below the bottom
Old 06-13-2012 | 09:26 PM
sup man! posted at the same time weeiiird lol how do they make a bravo into a -1?
Old 06-13-2012 | 09:30 PM
Order a case (new or used) from imco and cut the drive shaft. Call skip (or ronnie) and he'll take care of ya. If I remember it wasn't too bad of a price. I almost did towards mid summer until I had to replace the gimbal.
Old 06-13-2012 | 09:38 PM
ah gotcha i just have to figure out if 2" below the bottom is too high without having a stand off box. i hate that im a speed junkie!
