I had cleavers like those on an old Scarab 30ft. They worked well on TRS buried real deep. Not sure how well they work on Bravos at a shallower depth.
I remember this boat from years ago and it seemed to move pretty good on the lake. It might be a different situation if it was offshore and running hard for a long time with unlimited room to play.
It's been quite a while. I took on some extra assignments at work and traveled a bit, but now things have finally settled down with a promotion and working closer to home. The good news is winter is over and today I FINALLY received a title for the project boat with my name on it. So it is back on the front burner and will start getting some attention again. I just couldn't put anymore effort into it without having the paper in my hand that says it's mine.
Originally Posted by inthetundra
(Post 4118633)
He's doing good. He's laid off for a couple weeks right now. He worked all through the winter doing the grunt stuff and logs, but he finally got wet a couple times a week ago. His crew even got mentioned in the paper because they found a guy the cops had been chasing on one of the intakes of the dam in the Dells. Pretty happy about finally having the title for this thing. At least now I can do with it whatever I want.
I still am not getting enough time off work to seriously work on the boat. I did manage to get the motor back together and fired up. The only leaks were a hose clamp and a riser bolt that needed to be re-torqued. I'm pretty happy about that. I hope to get it in the boat in a few days, just need to make the bracket for the oil cooler first. I tried to add the video, but it doesn't seem to load
https://www.facebook.com/photo.php?v=10152634620334287&set=vb.721414286&type=3&theater |
| All times are GMT -5. The time now is 01:51 AM. |
