New project
Old 07-27-2012 | 08:57 PM
  #71
the deep's Avatar
Fast Singles Club
Veteran: National Guard
I have the stock thermostat housing off my HP 500 if you can use it it's yours .
the deep is offline
Old 07-27-2012 | 09:42 PM
  #72
This is what I need I guess to match the other engine. I think the bottom is a 87110 and I know for sure the coever has 47440 on it
inthetundra is offline
Old 07-27-2012 | 09:48 PM
  #73
the deep's Avatar
Fast Singles Club
Yes , exact number match . Go figure , i told you it was getting spiritual .
the deep is offline
Old 07-27-2012 | 10:30 PM
  #74
Very cool gesture, I sent you a PM.
Thanks again,
Art
Old 07-27-2012 | 11:06 PM
  #75
Default fixx
It may not look as fancy as what some of the other boats have, but it's in my garage and will be all cleaned up before going in. I just need to find the right thermostat housing now that I got rid of the heat exchanger. This is farther than I expected to be this year.
i hate to ruin your evening but see if a magnet sticks to the intake manifold,if it does its not a mag engine..from looking at the rust on the intake made me ask the ?.. if you are going to use it anyway your going to be making a left or right while trying to plane off..
FIXX is offline
Old 07-27-2012 | 11:17 PM
  #76
the deep's Avatar
Fast Singles Club
Did they come with a squarebore or spreadbore intake ? Carb was changed for sure . Maybe so was the intake . We need to investigate .
the deep is offline
Old 07-27-2012 | 11:35 PM
  #77
Default fixx
intake has rust on it,mag intake is alunimum,also a round port intake wont work on a mag engine with square port heads,,it would have a huge vacume leak .. edelbrock carb has q-jet or holly bolt patterns..
FIXX is offline
Old 07-28-2012 | 12:00 AM
  #78
I guess this one needs to be explained to me
I knew the carb was changed to an Edelbrock carb
The original engine intake is aluminum, this one is cast. Original engine was rated at 330hp. I was told this one was rated at 330 hp at the crank
Many new parts, the following components all have less than 300 hrs of use:
Cylinder heads done by reputable local machine shop
Performance cam & timing gear by same shop
Closed cooling pump
Rebuilt raw water pump
Fuel pump
Heat exchanger
All belts & hoses
Edelbrock carbeuretor
Engine wiring harness w/ 10 pin connector
Ignition coil, distributor cap, plug wires
Platinum plugs
Alternator
Starter
You didn't ruin my evening....things are still going to work out in the end!
Old 07-28-2012 | 12:21 AM
  #79
If the boat floats and goes and I am happy...I can always find a matched pair over the winter to drop in!
Old 07-28-2012 | 12:38 AM
  #80
Default fixx
as long aas you dont harm anyone then i guess it will work..
a mag is 365 hp and the one you bought is 330 + what ever the old owner did to it..a mag you can rev to 5k a 30 4600 rpm's,a mag has forged internals and 7/16 rods the 330 has cast internals and 3/8 rods..
hope it all works out..
goin to bed see ya!
FIXX is offline
