Torque Engineering V-12
Old 09-03-2012 | 09:35 AM
Thanks for the drive info. Will contact in the morning. Motor will be back from MI next month. If that drive can hold up to this application that will be great! The boat weighs 9800 lbs with vac flush/ac/gen, and is a nice entertainment boat. The 2 speed trans was not in the vessel when I pruchased it, just a good old velvet.. Once the boat is back the water plans are to install a 2 speed and then twin super charge. At that point we will run into drive problems again. An outfit in Missouri is getting upwards of 3000 hp from this Torque motor...
domiman is offline
Old 09-03-2012 | 07:52 PM
Handles 1500hp, not cheap, but very unique!
http://www.weismann.net/Press%20Page...annDuoProp.htm
bert4332 is offline
Old 09-03-2012 | 10:00 PM
Registered User
What is this torque engineering V-12 engine?
Pictures??
Inquiring minds want to know!
Dkahnjob is offline
Old 09-04-2012 | 09:32 AM
Thanks for the info on the Weismann. The boat has a notched transom so I can't use a surface drive..
domiman is offline
Old 09-04-2012 | 09:43 AM
As I'm told, the Torque Engineering Company was to offer an IPO just prior to 9-11. They were a start up company from Elkhart Indiana. They were going to change the pleasure/race boat market as we know it. They manufactured a V 12 in four platforms. 900,1000,1100 and 1400 hp. Several factories signed up and took delivery of these rare motors. When 9-11 happened their IPO was taken off the table and the company went bankrupt. I'm not a motor head, but from I'm told my motor has real fuel injection with an Indy car computer and several other unique attributes that give it amazing torque and horsepower. I was lucky to track down the original motor build who is freshing mine. With only 8 hours total run time it did not need much. He changed out the valve train to create much more hp. Details to come!
domiman is offline
Old 09-04-2012 | 11:04 AM
fantastixvoyage's Avatar
Does yours have a gear or belt drive for the front accessories? From what I understand (and I could way off) there was an issue with the harmonics created from the original geared setup that was later fixed via a more typical belt assembly. I think Sterling had a hand trying to bring back this engine.
Would be nice to see these make a comeback but who knows if the tooling even exists. Glad you found the support you needed to bring yours back to life.
fantastixvoyage is offline
Old 09-04-2012 | 11:09 AM
WildThing47's Avatar
I thought Cosker bought the rights and Sterling bought out the motor program for these and had the rights for the motors?
They were too expensive and exotic and never ran correctly from what I've heard...custom parts, few guys on here can attest to that I think.
Brad Smith has a set too right? I don't know, just from my readings, good luck on the project...
I always thought those sage drives were really cool, being able to change the x dim on the fly etc...perhaps too complex for the standard non racing high perf owner...
WildThing47 is offline
Old 09-04-2012 | 01:26 PM
Pictures??
http://web.archive.org/web/200201220...torquev12.com/
TexasVines is offline
Old 09-04-2012 | 03:31 PM
WARPARTY36's Avatar
Drive to arrive alive!!!
I think Brad has been playing with a set of these. Last I heard, most of the Torque stuff was in Marietta, Georgia.
WARPARTY36 is offline
Old 09-04-2012 | 05:20 PM
Wow! Glad to see someone out there knows about these motors! They did have internal drive problems with the alternator but mine(thank goodness) has been retro fitted. They never ran correctly due to mapping issues that the software programmers could never figure out(fixed on mine). Jerry Sample is the original builder and was around from start to finish and at the end, ended up with most of the tooling and parts. I still need to solve the drive issue. Ideas???
domiman is offline
