Where can I find info on Cats vs Deep Vee
typically cats are 20-30mph faster than vees with identical power. For example I had a 28 Daytona with twin 496 mags (375hp each) the boat went 91, a 28ft vee with similar power will be 65-75mph top end. At cruise 70mph I got 2mpg, that would be basically wide open in a vee with the same power. If your interested in top speed and don't need to be in the ocean in 4+ ft waves on a regular basis get a cat, the ride, mpg, and handling are much much better than a vee. If you want to bang around in rough seas a vee is the way to go. I'm sure somebody will pipe up that some 28 vee is faster than what I have said, like a Donzi 28ZX Scorpion, which runs in the high 70's, difference is that boat has small blocks which weigh less. Bottom line get a cat, I have a vee now and I cant wait to get a cat again, somebody just needs to build a nice center console version.
Without comparing specific models, its like asking what is the difference between red cars and blue trucks......
What I mean is there are many different V-Hull designs and speeds can vary greatly based on hull design and weight with equal power. A 32' Baja with a traditional V-Hull with heavy construction will be much slower than 32' Velocity with lighter constructionan pad bottom. Now add steps (number of steps), etc. Same with Cats, Skaters, DCB, Eliminators, all use different methods of hul design and construction, therefore they all will have different speeds and handeling.
Your question of what is the difference between a v-hull and a cat with equal power is too vauge.. Like asking whats the difference between a red car and a blue truck..
There are many people on this board with great knowledge of the different brands and designs. If you ask a more specific question, I am sure you will get better more specific answers.
Like many people here, I have owned both & after 25 years, I love cats. But I suggest you start out in a vee. It is cheaper and a safer way to cut your teeth before you break into the 100MPH+ club of cats. But the cat ride is so much better on your butt.....
Remember Cats come in either Full Tunnel (Skater, MTI, Nortect) or Center Sponson (Talon, Eliminator, DCB) . Center Sponson is not as good as a full tunnel in Rough Water other wise not much difference. V Huills come in either Stepped Hull (betwen 1 and 4 steps sometimes) and they handle differently especially in and out of turns). I have owned 2 Big v's (Formula 382 and 37' Outlerlimts)
and now a 36 Skater. I enjoyed the V Hulls because of the Cabin and overall comfort when sitting still but to me the Cat is just way more fun in every aspect of driving a boat except maybe in rough Ocean Conditions. I like the advice provided above start with a V Hull with a Stepped Hull. Don't be afraid of a Stepped Hull just learn to drive one correctly. A Stepped Hull normally is faster than a Non Stepped hull with the same power by 10% or more. Have fun
