Sanding a lower unit for speed >
Old 10-07-2012 | 10:06 AM
I keep mine sanded, i started with 60 then 80 then 120 and finally 220. I keep them shiney with a 3M scotchbrite red pad and wd40. being as i have really done nothing other than make them satin finish, other than looking good i couldnt tell ya.
Might want to try veggie oil vs WD40...a little more enviro friendly.
JRider is offline
Old 10-07-2012 | 10:23 AM
Originally Posted by scarab63
5 mph net is pretty DARRn good for some elbow grease.....
What's the secret hex film called...?
http://www.proboat.com/blueprint-for-speed.html
Interesting, most of us just keep adding HP
Curious to see if any DIY'ers on this site have trued a lower unit themselves.
4bus is offline
Old 10-07-2012 | 11:56 AM
Originally Posted by nova26
What kind of boat?
I'll bet it's a Skater...
redbud35 is offline
Old 10-07-2012 | 12:20 PM
very interesting read... if it wasnt 5k i'd consider it
AJ POWERPLAY is offline
Old 10-07-2012 | 12:50 PM
Its proprietary and called hex hyde. Its in testing phase on 2u boats right now. Results will be available soon
yarrowtavern is offline
Old 10-07-2012 | 08:02 PM
Default no worries
Originally Posted by bwd
Better put motor in before you bother sanding your lower. Just sayin. LOL
Heads getting flowed now.
It'll b back together soon.
Don't u worry bout me Mr...u know I like to stack my plate high.
scarab63 is offline
Old 10-08-2012 | 08:50 PM
Lauderdaleboats's Avatar
Having a true straight lower on a twin engine appllication is beneficial but i don't think this is the case on a single engine app.
Outboard drag racers have been sanding/profiling lower units for many, many years, and straight was not what they were after. Running a high x dim will result in increased speed but on a single it will try to prop walk. Prop walk will cause the driver to crab the lower to keep the boat in a straight line. Look at the skeg mounted torque tabs on the fastest of outboard drag boats and you wouldn't believe the curve. Drag boat skegs running right hand rotation props will have the stbd leading edge ground on back to mid skeg. On the port side, from mid skeg back to the trailing edge is ground on. This curved skeg is the fastest setup on a single engine.
Lauderdaleboats is offline
Old 10-08-2012 | 09:05 PM
glassdave's Avatar
Neno the mind boggler
never really thought about it but that makes a lot of sense. Interesting . . . . .
08 OPA High Points Champion
glassdave is offline
Old 10-08-2012 | 09:40 PM
CLA
I talked with Steve that owns RPM and he said the same. I believe he is putting tq tabs on his lowers on those little cats.
CLA is offline
Old 10-09-2012 | 05:09 AM
bwd
Very interesting.
bwd is offline
