Gil Manifold Owners.. Help!!!!! >
Old 07-13-2002 | 10:23 PM
stevejohns
Default Gil Manifold Owners.. Help!!!!!
I have a used set with no instructions. Inc was the shifter , elec and oil filter brackets but I cant really figure out which ones to use where and especially the oil filter. thanks for the help. sh
Old 07-14-2002 | 12:31 AM
R Addiction's Avatar
AT Cult Member #3
What motor ......carb,.....MPI?
R Addiction is offline
Old 07-14-2002 | 01:35 AM
stevejohns
Its a 502 carb.. heres what i cant figure out. there is 2 plates about 6x5 ican where it lines up nicely with the shifter assembly. The other one could go on the other side to attach the ign. module.
BUT ! there is 4 brackets made from flat iron bent into a modified Z with holes on ea. end and with side gussets. 2 are identical , 1 is the same ize and shape but has a flange welded about 1/2 way up with hole drilled in the flange. the last of the 4 is the same shape , about an inch longer with no side gusset. Im guessing they are for the oil filter bracket but i cant see needing more than 2 and cant see how exactly to attach the filter brack to them. thanks for the help...sj
Old 07-14-2002 | 11:05 AM
stevejohns
top
baja36ft
3
05-06-2005 05:56 PM
Bote Loco
3
06-26-2003 03:43 PM
formula31
4
10-13-2002 07:15 PM
formula31
10-13-2002 03:02 PM
stevejohns
5
07-15-2002 08:27 PM
