1700HP Pump gas engines
Old 11-05-2012, 06:18 AM
What kind of heads and valve train are beibg used on this beast. Is this the same builder that had a really nice looking set of twin turbo engines on a threade several yeras ago.
Enough 4 Play is offline
Old 11-05-2012, 11:09 AM
BBB725's Avatar
The motors were designed using a clean sheet of paper everything is new.
The block, heads, intake, brackets are all machined from billet aluminum.
3 years ago the designer Todd Goodwin got tired of fixing motors that broke and thought he could design and build one better. The original intent was for truck pulls, wanted 650 cubic inches and 9500 rpm.
BBB725 is offline
Old 11-05-2012, 11:10 AM
BBB725's Avatar
Look here for pictures and more
http://forums.boatfreaks.org/showthr...t=23790&page=2
BBB725 is offline
Old 11-05-2012, 10:29 PM
Originally Posted by BBB725
Thanks BBB
Is Goodwin a Marine Engine Builder? I never heard of him before this. Or is his specialty in other types of racing engines?
Just curious.
1700HP on 93 is beyond impressive. I have not heard of anyone else near that number on blowers only turbos.
Cavanti53 is offline
Old 11-05-2012, 10:42 PM
cigboat1's Avatar
Nice engines---- BUT are they going to hold together for more than 100 hours and will they cost a lot less than $204,000.00 each ????????? a little shot at Merc!!!!
Jim
cigboat1 is offline
Old 11-06-2012, 09:44 AM
BBB725's Avatar
Originally Posted by Cavanti53
Thanks BBB
Just curious.
Goodwin does alot of stock cars and drag cars, his big claim is in porting heads. Over the years he's built marine engines for myself and others locally.
Jim
I believe these motors in N/A form are around $70K, but that you'd have to confirm with Goodwin. FWIW I ran some Goodwin motors, 598ci 750hp in my boat for a couple seasons and never had a hiccup, but these are completely new animals.
BBB725 is offline
Old 11-06-2012, 02:14 PM
Whipple Charged's Avatar
Originally Posted by freshwaterfiend
Are these normal BBC's or the bigger 5" bore spacing?
5" bore spacing. They ran on 91 octane on the dyno. On 110, there is no problem making 2200hp.
Whipple Charged is offline
Old 11-06-2012, 02:20 PM
Jim
There certainly cheaper than $204,000. The motors have the same PCM as a 1075, they idle at 1000rpm, run 13:1 at part throttle, idle, mid range for "economy" mode and make a ton of power. PCM has all the safety settings to not let full power until oil temp is up, fuel psi compensation, knock per cylinder, water psi safety, temp..... Air fuel per cylinder is within .25 of eachother pretty much everywhere. Quite impressive and Goodwin did an incredible job with all the work on the engines. The motors in person, are truly a work of art.
Old 11-06-2012, 05:37 PM
Do u have to use a quad rotor setup or could it be like a 8.3 whipple for example? Maybe a dumb question...
precisiondetails is offline
Old 11-06-2012, 07:07 PM
Either would work but the quad 4.0L would be better when its stepped up to race gas. This has the one piece throttle body with progressive linkage.
