Cummins 6BTA 5.9 Performance Build >
Old 11-22-2012 | 07:12 PM
  #101
Originally Posted by HabanaJoe
JD do you have a pic of a triple set-up like yours not in the truck but on a stand?
I might be able to dig one up. The manifold had 2 50mm waste gates in between hole 5&6 and 1&2, which was combined and was plumbed into the intermediate pipe after the second stg charger. The second stg charger was pretty small so those gates where needed to drop bp and prevent it from over spinning. I actually had regulators in the cab of my truck and could make adjustments on the gates to control the boost. The gate at the end of the intermediate pipe was the one I would make adjustments to the most. I could make it make 67 pounds and no more with the regulater if I wanted.
JD Dearden is offline
Old 11-22-2012 | 07:16 PM
  #102
Heres a cool pic of a tubular exhaust manifold for a compound set up on a 6.7 cummins. Just thought I would share, doubt it would help a marine application much besides in the BLING department!
http://lovefab.com/
They specialize in custom turbo kits and manifolds for the Acura NSX, Import tuning, and some diesel stuff.
offshorexcursion is offline
Old 11-22-2012 | 07:26 PM
  #103
They did that so all the ports where equal length. Looks good but does nothing for performance.
Old 11-22-2012 | 07:29 PM
  #104
you run an air to air cooler, do you monitor temp after the cooler?
When do want want to bring nitrous into the conversation??? How does four solenoids sound and a common rail system sound.
Old 11-22-2012 | 07:51 PM
  #105
I'll tell what, I now you're priming me BUT I'll always that that would work great to get on plane after that you can't carry enough to use but would solve the problem.
You needed to look at the old UIM/APBA rules when racing was racing! A diesel boat could not carry anything else but the diesel, you were allowed to start the engins on other fuels but not run the boat on them.
I remember the Italians with the big Isotta's use to spray something other than ether to start them I though it was gasoline?
HabanaJoe is offline
Old 11-22-2012 | 07:54 PM
  #106
It works well with diesels. Especially the progressive controllers.
My buddy built this to fog.
http://m.youtube.com/watch?v=gdQH3YzkEMI
Old 11-22-2012 | 07:58 PM
  #107
Yea, that scares the crap out of anyone just looking at it!
Old 11-22-2012 | 07:59 PM
  #108
Very cool, but how long would a bottle last or how big for a 2 hour bottle?
Old 11-22-2012 | 08:03 PM
  #109
We had two 35 pounders in the lightning and it would last 4 runs hahaha.
Old 11-22-2012 | 08:25 PM
  #110
glassdave's Avatar
Neno the mind boggler
Hey can you give a quick explanation of what's going on with that exhaust and what compound means? Just looks pretty wild and I am curious what's going where. Thanks
08 OPA High Points Champion
glassdave is offline
