View Poll Results: Bravo XR drive breakage
Broke upper gear set
71
82.56%
Broke lower gear set
15
17.44%
Voters: 86. You may not vote on this poll
Old 12-20-2012 | 10:38 AM
XR gears in an IMCO case , upper gears pitted and started going away . But that's with about 850 HP
HALLETT FAN is offline
Old 12-20-2012 | 10:51 AM
H20 Toie's Avatar
Couple of uppers for me
lowers are all good
H20 Toie is offline
Old 12-20-2012 | 01:32 PM
Upper gear set and top cap - HP525
Allirunner is offline
Old 12-20-2012 | 02:42 PM
funny, I had 2 600hp behind trs in a heavy old formula never had a problem
JMPH is offline
Old 12-20-2012 | 03:59 PM
Tom A.'s Avatar
Broken both top and bottom but def. 3 or 4 to 1 top over bottom.
Tom A. is offline
Old 12-20-2012 | 04:15 PM
hammer01's Avatar
I've replaced several upper gear sets just due to normal wear. I think someone already touched on the fact that it is a marketing item for Merc rather than quality control. No diff than GM installing non-grease able fittings from the factory so you have to replace them.
hammer01 is offline
Old 12-20-2012 | 05:04 PM
Does it matter which direction the drive is rotating. I ask this to wonder if the load is on the top cap or the floor of the case.
tbanzer is offline
Old 12-20-2012 | 05:22 PM
Funny that back in 1988-1991 era, you had a couple options when choosing power in most offshore boats.
(Black Mercruisers)
454/330HP=Bravo one
454/365HP=Bravo one
502/390HP=Bravo one
(Mercury High Performance)
454/420HP=TRS
502/465HP=TRS
Anything bigger than that you got SSM IIIA, V, and eventually 6. How about the early 525SC hooked to a SSM IIIA? Talk about reliable!!! A drive rated for 750HP couple to a 490HP engine.....its like a XR behind a 454/310HP MPI.
At that time, you could not even get a 454/420HP Merc Hi-perf engine coupled to a Bravo from the factory. So, I would put a TRS/72C up against a Bravo, or bravo XR any day. Now if they had kept the TRS, and made some shorty lowers for them, that would have been cool.
MILD THUNDER is offline
Old 12-20-2012 | 06:28 PM
glassdave's Avatar
Neno the mind boggler
yes it does, the left hand drive pushes up on the top cap under power and, in my case, stretches the bolts allowing the tolerances to go out.
08 OPA High Points Champion
glassdave is offline
Old 12-20-2012 | 06:30 PM
sorry, but this poll is like asking everyone who attends an aa meeting "raise your hands if you like to drink"! we all know that the bravos break and break yet you keep going back to the fountain for another desperate cure. why not start a poll on the alternatives to bravos rather than the next drug for bravo owners? the reason everyone is hooked on these things is that so many mechanics are making their living off repairing them to the extent it would be finical suicide to recommend or have the customers change to anything else.
Boatlesss is offline
