454 questions....
Old 03-19-2013 | 08:42 AM
Default 454 questions....
Boat I got yesterday (95 avanti) had a 454 in it. got it with no motor. In the bilge I found a seawater pump, alternator, exhaust manifolds and risers, distributor, power steering pump, coupler and other misc brackets and pieces parts.
There are different gens, heads and stuff, not sure if it was the original motor but sure it was a merc 330. All Im looking to do is get it runnable for the summer, no major power or anything fancy as its getting an outboard conversion this winter.
So does anyone know what long block/donor motor Im looking for or is all the 454 stuff basically interchangable?? Im thinking all I am needing is the longblock, intake manifold and carb.
phragle is offline
Old 03-19-2013 | 10:54 AM
fireboatpilot's Avatar
RIPSTA Racing Team
Post some pics of the brackets and such so we can see what types they are and should be able to determine what blocks will work for you
fireboatpilot is offline
Old 03-19-2013 | 11:57 AM
I have a stock 7.4 efi complete -ready to drop in
pm me if your interested
mike
JETTDOGG is offline
Old 03-19-2013 | 12:03 PM
Pretty much all 454's are interchangeable for the things you mentioned. Flywheels are a little different. Size is the same but the balance is different from gen to gen. Also if you get into the motors them selves like Mark 4 heads on a gen V require special head gaskets but all the bolt on's fit the same. The only concern is the Gen V 454 has no place for a fuel pump to mount (even though you can use a cam with a fuel pump lobe in the motor) and you will either need one of those super expensive raw water pumps with a fuel pump mount or you will have to use a electric pump.
f_inscreenname is offline
Old 03-19-2013 | 08:35 PM
O.C.Barry's Avatar
Default Diff
The oil pans are different, (I have a GEN 4 and also a Gen 5/6 pans, I can let you have cheap). You can also buy a new block from GM that is Gen 6 on the bottom end but takes Gen 4, Gen 5, and Gen 6 heads (we have one on the raceboat) The front covers are different also (I have a GEN 4 and also a Gen 5/6 front covers I can let you have cheap). I also have several stes of nice valve covers.
Thanks, Barry
Driver - High's Fuel Your Journey Cigarette Racing Team #598
O.C.Barry is offline
Old 03-19-2013 | 10:35 PM
here are some piks of the pieces parts that came with it..
including a shot of the motor that was originally in it that wasnt winterized and froze...
Attached Thumbnails 454 questions....-gedc0963-copy-.jpg   454 questions....-gedc0964-copy-.jpg   454 questions....-gedc0965-copy-.jpg
phragle is offline
Old 03-20-2013 | 12:51 AM
OC Barry - I am looking for some valve covers for my twin 454 gen iv's. if phragle is not interested I may be. Thx
Port Monster is offline
Old 03-20-2013 | 05:40 AM
I have a 454/330 with 50hrs,out of a 97 outlaw,long block.oil pan to intake.tom 484 645-7456
500hps is offline
Old 03-20-2013 | 08:14 AM
Your looking for Gen 4 BBC - from what i can tell.
What drive is on it?
Wannabe
wannabe is offline
Old 03-20-2013 | 08:42 AM
If it froze you can pretty much bet the exhaust and coolers are junk as well.
Everything you have in the pictures is compatible across the generations. Like others have stated, oil pans, gaskets, seals, internal stuff and fuel pump provisions are the things you have to look for.
4bus is offline
