Cockpit lighting?
Old 03-24-2013 | 06:48 PM
Full Force's Avatar
Default Cockpit lighting?
I need to add cockpit lighting to my Mistress, what is a good affordable light? what looks good? I might want red, or just clear, is red bright enough? Most likely go LED...
Probably gonna add 4 total??
Full Force is offline
Old 03-24-2013 | 07:21 PM
Try here www.superbrightleds.com
Flamingo 42 is offline
Old 03-24-2013 | 07:27 PM
Nightlife1970's Avatar
You can buy a full RGB LED setup and do any color you want. Cost less than $30.
Nightlife1970 is offline
Old 03-24-2013 | 07:30 PM
Full Force's Avatar
What would a good wattage be?
Old 03-24-2013 | 07:31 PM
Full Force's Avatar
Originally Posted by nightlife1970
you can buy a full rgb led setup and do any color you want. Cost less than $30.
rgb?
Old 03-24-2013 | 07:35 PM
rgb?
http://www.ebay.com/itm/5M-5050-RGB-...item4d009baa33
You can do just about what ever you want with this stuff. In the cockpit I see no reason to need waterproof.
RGB = color mixing has three colors on the LED that mix to make any color.
glassdave's Avatar
Neno the mind boggler
Whatever you use make sure its indirect and you cannot see the actual light source. In my Scorpion I cheaped out and got a half dozen or so of those foot long 12V fluorescent work lights and hard wired them in and mounted one under each bolster and under a couple other pockets and ledges around the cockpit. Looked great lasted as long as I had that thing, people always commented on them. I prefer white
These things
http://www.ebay.com/itm/6304-ALL-WEA...e29c66&vxp=mtr
08 OPA High Points Champion
glassdave is offline
Old 03-24-2013 | 07:39 PM
Full Force's Avatar
I cant hide that stuff anywhere...
Old 03-24-2013 | 07:41 PM
Full Force's Avatar
These things
Loive the idea, but I have no place to hide them in the Cig..
Old 03-24-2013 | 07:44 PM
Why not? I can't imagine a boat it wont work in. Stuff is small and flexible and bright. I don't see why you could not use the stuff to convert what you have now.
Got any pictures of the cockpit.
