Prop help?
Old 04-01-2013 | 02:28 PM
Default Prop help?
Anyone have a 27p mirage plus either LH or RH is fine. Something someone isn't currently using that I could use for testing. Thanks!!!
rob vanharten is offline
Old 04-01-2013 | 03:41 PM
I have a pair of them in perfect shape, don't really want to split up the pair though
http://www.offshoreonly.com/forums/s...s-27p-l-r.html
pstorti is offline
Old 04-01-2013 | 03:46 PM
Rob I will check when I get home I may have a 27 rh that you can use for testing. Can't remember off hand stay tuned.
abones is offline
Old 04-01-2013 | 05:29 PM
Sorry Man just looked and the only 3 blade remaining is a 25 mirage (not Plus) solid hub for 1 inch shaft. I believe the 27s sold as a set. Sorry Rob!!!!
abones is offline
Old 04-01-2013 | 06:01 PM
Hey thanks for looking!
Old 04-01-2013 | 07:29 PM
Rookie's Avatar
I have a pair of 27" Mirage at the shop. Don't know if they are a Plus or not but they're yours to try. I have about 5 sets of props if you want to try them.
Rookie is offline
Old 04-01-2013 | 08:42 PM
Perfect, thanks bud. You going to be at the shop on Saturday?
