Page #248, from pic #5-10 clearly shows everyone keep in line with the M41 cutting left too early, squeezing everyone else! He had ample room to proceed another few hundred feet.
After watching the vid again...another thought...there were several boats on his side, did he try to piuposely cut across to get some running room??
Originally Posted by Level III Chaos
(Post 3916959)
Chopper two view:
Hmmmmmmmmmmmm |
(Post 3916961)
But.......NUMBER ONE (winner)?
Compare the 41 DCB's proximity to Skater40 in all the different pictures. If the 41 didn't cut the corner, then Skater40 moved well to the right. Both boats were running next to each other early in the run and then the gap between them widens siginificantly as the accident occurs. Either the 41 moved to the left or Skater40 moved to the right.
Originally Posted by BraceYourself
(Post 3916930)
I disagree.
The 41 was staying about the same distance from the shore. It looks like he's going left because he has to because of the left hand turn of the lake. The 35 just is to far to the left to start and decided to swap sides of the 41. He's the one to blame. He should of never cut that close behind the 41. If you look at the footage aprox 5 sec from the end The blue 388 skater was far left of the entire pack .( JT throttling I believe) When the river turned left and things got a little tight, he backed off, stayed in his lane, (held his line) and was able to turn left and pass the oncoming traffic with plenty of room to spare. If the Dcb that flipped did the same , there would have been no incident. Either he was over trimmed and couldn't turn or just decided to go for it and cross the wake for better position to be the first to the first card stop. |
So if the M41 DCB did NOT change his "line" in front of other boats and the M35 DCB should have choose to make a tighter left hand turn to AVOID crossing the Rooster tail of the M41 DCB, then what would have happened to the boat to the port, left, of the M35??? It would have ran up the M35's Rooster Tail resulting in the same accident, different boat!
Its pretty obvious, the Silver M41 DCB was the first to accelerate which started a chain reaction of bad events. No one can argue that the Silver M41 DCB "jumped the gun" and took off BEFORE they were told to. That in itself is enough but to top it off they also turned left in front of the pack, with half the EMPTY lake in front of them they could have used. But hey, I guess first to the card stop means more then others lives..... At those speeds there is not much time to react, there is NO other option the M35 had that would have been 100% perfect. EVERY option "line" they were delt with (by the M41) put them in a dangerous situation. By the time they M35 saw the M41 "take off", made a decision to join and "take off", probably checked over their right shoulder, left shoulder, looked back ahead, CHIT, no time to react! |
Originally Posted by offshorexcursion
(Post 3917209)
Not sure what video people are looking at that say the 41 didn't cut anybody off, but I'm looking at the one posted by Braceyourself, post 244 I think. That cut off is so obvious that Ray Charles and Helen Keller could see it... He's the only boat that took off like bat out of hell, then shot left right in front of the entire pack...
fixx
Originally Posted by tim mccray
(Post 3917215)
| All times are GMT -5. The time now is 03:42 AM. |
