Cleaning the outside of the boat >
Old 05-08-2013 | 06:54 PM
Default Cleaning the outside of the boat
so I started to wash the boat, I used a west marine orange boat wash, it didn't clean ****. what products are you using on the outside of your boat. i'm trying to clean:
1) waterline marks
2) some yellowing of the bottom
3) black exhaust at the rear of the boat
if I use a buffer, would a rubbing compound clean it ? any suggestions on make of compound ?
any good wax recommendations?
taillight is offline
Old 05-08-2013 | 07:00 PM
I was told "on off" works wonders, its abrasive but cleans, just gotta rewax after your done! Ive bought some just havent used it yet! My buddy uses on his all the time......
badz4u2nv is offline
Old 05-08-2013 | 07:28 PM
I use this stuff... works amazing
http://slimygrimy.com/
chrisf695 is offline
Old 05-08-2013 | 07:40 PM
Be careful with on/off. Very toxic, will damage trailer with many uses. It is acid, be careful of fumes too.
sonicss42 is offline
Old 05-08-2013 | 07:57 PM
BioKleen Hull Cleaner works on all that stuff!
07DominatorSS is offline
Old 05-08-2013 | 08:21 PM
ROB FREEMAN's Avatar
toilet bowl cleaner
ROB FREEMAN is offline
t500hps's Avatar
21 and 42 footers
River bottom brown on the hull and black exhaust need much more than soap. I used a diluted mix of on/off and then re-waxed after. If I waxed the hull twice a year the stains wiped right off for a few months.
t500hps is offline
Old 05-08-2013 | 09:11 PM
Simple Green on the transom. Use a "drenched with water" rag so the exhaust doesn't just streak!
DirtyJerz is offline
Old 05-09-2013 | 12:29 PM
Buff with 3m marine cleaner wax, works very well! I know a few marina's that swear by it. Worked great the times I have used it.
Jordan is offline
Old 05-09-2013 | 12:42 PM
Knot 4 Me's Avatar
1) waterline marks - straight vinegar or hull cleaner
2) some yellowing of the bottom - The Works toilet cleaner (cut 50/50 with water)
3) black exhaust at the rear of the boat - Simple Green
Knot 4 Me is offline
