Hydraulic steering hose
Old 06-07-2013 | 06:39 AM
Default Hydraulic steering hose
Anyone on the site make hydraulic hose I need to have hoses made for steering on a 311 formula
353Formula is offline
Old 06-07-2013 | 07:57 AM
I have had hoses made locally at an Ace hardware store. They even had stainless fittings. That was years ago and I found them in the yellow pages.
JRider is offline
Old 06-07-2013 | 09:05 AM
Or call these guys and make your own.
CP Performance - Performance Marine Parts, Boat Parts, Marine Engine Parts
abmotorman is offline
Old 06-07-2013 | 01:20 PM
Any tractor/equipment dealership (Cat, JD, Komatsu, etc) will be able to make hoses in house.
Cole2534 is offline
Old 06-07-2013 | 02:31 PM
c_deezy's Avatar
Parker or Aeroquip shop can do it also.
c_deezy is offline
Old 06-07-2013 | 03:46 PM
Dave M's Avatar
Veteran: Navy
They aren't too hard to make either. The hardest part is cutting the hose.
Dave M is offline
Old 06-07-2013 | 10:10 PM
Doug, I had all new ones made by Pirtek in elk grove. I'm pretty sure there is more than one location
FANTAZ28 is offline
Old 06-08-2013 | 03:53 PM
JnT's Avatar
JnT
NAPA auto parts can make them as well. The hose is USCG approved too. Its expensive though.
JnT is offline
Old 06-08-2013 | 08:30 PM
ChrisK's Avatar
Moderator
I have a crimper for our trucks and equipment, its not hard to make them, but you do need a specific crimper for the specific hose you have. There are tolerances that need to be met. That said i'm sure there are plenty of people in your area who can make a hose for you. Almost any equipment repair place can, as well as many NAPA auto parts stores. If available I would look for a PARKER hose store or someone who uses parker hose and fittings, they are a much better quality hose and fitting than gates and a few others out there. I have used different brands and had issues with the others until I found Parker. I have a Parker crimper and use them to supply me. I do believe they are marine rated fitting also, you can ask them. Also take your old hose to them when you need the replacement made, many times you need to clock the fittings to the correct angle so the hose will fit without any issues.
ChrisK is offline
