Alpha gen 2 shimming question >
Old 06-21-2013 | 10:57 AM
Default Alpha gen 2 shimming question
Do I need to redo/check the shimming of the upper gears? I just replaced the yoke and oil seal. The bearings are all the same. Thanks
jbizub5192 is offline
Old 06-21-2013 | 02:50 PM
Panther's Avatar
Frank's Marine Service
If all you did was replace the yoke shaft and seal with all the bearings and gears being the same you don't need to re-shim.
Panther is offline
Old 06-21-2013 | 11:00 PM
Ok thanks, thats the answer I was hopping for. When do you typical need to re-shim, only when you replace gears/bearings?
Old 06-22-2013 | 09:33 AM
You do need to set the Rolling Torque tho.
pi75 is offline
