Latham Steering Reservoir Question >
Old 07-14-2013 | 08:12 PM
Default Latham Steering Reservoir Question
I just installed a Latham steering reservoir to complete my full steering system. But I have noticed after every run there is a little fluid on the top of the reservoir coming out of the vent. Check with a friend and had the same thing going on and said it is normal.
Has anyone created a setup with a blue anodized cap that does not vent out the side? Or is there something else that can be dome to still allow venting but not have to collect on the outside of the reservoir?
Thank you for the help in advance.
TW720HVY is offline
Old 07-14-2013 | 08:58 PM
Put a solid cap on it, no need to vent. All hydraulic steering systems other than boats don't vent. Pressure is ok will only make 5 lbs.
43sv is offline
Old 07-15-2013 | 08:20 AM
Thank you for the reply, I will look for a non venting blue anodized cap.
TW720HVY is offline
Old 11-05-2013 | 02:58 PM
I have this problem as well but it is so bad that it leaves a puddle under my boat every time. Seems it's gotten worse over the past year. Any other fixes?
erichuegele is offline
Old 11-05-2013 | 08:44 PM
Install a diaper on top of tank problem solved.
river boater is offline
Old 11-05-2013 | 09:37 PM
Wobble's Avatar
SORE MEMBER
I run a cap that leads off to a remote merc drive reservoir, can be wired into mercruiser alarm system if you wish,
here is the cap http://teaguecustommarine.com/catalo...ring+reservoir
no misting or drips
Wobble is offline
Old 11-06-2013 | 08:32 AM
I like this idea!
Do you have any pictures of your set up?
Maybe it comes in blue?
TW720HVY is offline
Old 11-06-2013 | 07:51 PM
Wobble's Avatar
SORE MEMBER
Originally Posted by TW720HVY
I like this idea!
Dont have a good picture handy, the cap could easily be re-powdercoated I'm sure.
I am very happy with this solution, it is surprising how much the level in the reservoir varies according to running time/temp
I used this style bottle so that I would get an alarm for low fluid http://www.ebay.com/itm/OEM-MerCruis...00027167193%26
Full hydraulic steering is not much use without the fluid
Wobble is offline
